Rpm indicator acting weird - Kawasaki Versys Forum
Like Tree4Likes
  • 2 Post By janda.m
  • 2 Post By fasteddiecopeman
post #1 of 15 (permalink) Old 03-18-2020, 01:54 PM Thread Starter
Can anyone help me with this issue? https://youtu.be/8pWJjHGsQz4
My bike is MKII 2010 with 52000km... From bottom to 4,500 rpm the Indicator jams.. From 4, 500rpm is smooth.. Its doing more than a year but now it is more often... Chain and sprockets are brand new.. Oil changed...speed sensor cleaned... Bought new spark plugs and
want to do vacuum sync on few days... I looked for kined wires and connectors but didn't find anything wrong so far... Thx
janda.m is offline
post #2 of 15 (permalink) Old 03-18-2020, 06:35 PM
Welcome From Canada
post #3 of 15 (permalink) Old 03-18-2020, 06:37 PM
Need a Second post
First until we get people back in administration ( requesting a change to one post and 24 hours) , you need a second post and 48 hours from that. Several areas are off limits to you. I am sending a PM to you.
post #4 of 15 (permalink) Old 03-18-2020, 10:56 PM
aboard.
post #5 of 15 (permalink) Old 03-19-2020, 01:01 AM Thread Starter
This is very weird rules
janda.m is offline
post #6 of 15 (permalink) Old 03-19-2020, 05:50 AM
you done with your second post. I pin my take on the speed sensor for you meter problem. Check wiring and speed sensor.
post #7 of 15 (permalink) Old 03-19-2020, 12:15 PM Thread Starter
Update... Now the Indicator works a while and stay stuck at 4500 rpms... Only way to set it down is a strong tap on the screen...
Wiring checked... I want to squeeze female pins maybe they are a bit loose due to vibrations... If the speed sensor is faulty it won't show the speed either did he?... What sensor is related to rpms? Speed sensor or crankshaft sensor? When in neutral only thing what spin is crankshaft so my guess it is crankshaft sensor 😕
janda.m is offline
post #8 of 15 (permalink) Old 03-19-2020, 04:13 PM
aboard!
post #9 of 15 (permalink) Old 03-19-2020, 06:44 PM
possibly more than one problem, that sensor is vulnerable to damage. There is s test in the manual for that . be aware on the MK-1 and MK-2 , some connectors were prone to corrosion , that is one of them, however your motor would run like crap because the ECU drives the display. There are posts on taking the display apart, many experienced problems with the reset button and clock button.
https://www.kawasakiversys.com/forum...pg-km-l-2.html
post #10 of 15 (permalink) Old 03-19-2020, 11:52 PM
i left a coment on your vid. check thaat. im going to go pass out now. yay boooooze...zzzzZZZZzzzzz
post #11 of 15 (permalink) Old 03-20-2020, 12:28 PM Thread Starter
I think I solved that out... I took apart the whole cluster.. Poped out the Indicator and used wd40... Putted everything together and now its moving smooth 😁
onewizard and Fastoman like this.
janda.m is offline
post #12 of 15 (permalink) Old 03-20-2020, 08:47 PM
jaaklucas's Avatar
siviefox,I know were supposed to self-distance ourselves in this pandemic but I didnt know we were supposed to self-medicate!
jaaklucas is offline
post #13 of 15 (permalink) Old 03-21-2020, 10:29 AM
It's good thing you're hanging out on this forum to learn the important stuff.
Glad to hear the OP has the problem licked.
Ride Focused.
'15 KLE650LT
'98 KLR650
And most of Canada too, eh?
SteveJ is offline
post #14 of 15 (permalink) Old 03-24-2020, 06:11 PM
always self medicating
post #15 of 15 (permalink) Old 03-24-2020, 07:08 PM
Let's here it for self-medicating!!!
(Sittin' here w/ a glass of Glenmorangie and water.......)
silviefox and jaaklucas like this.
