Hi from Germany - Kawasaki Versys Forum
post #1 of 11 (permalink) Old 02-28-2020, 07:27 PM Thread Starter
Darvin's Avatar
Hi from Germany
Just bought my x300 but have no driver licence yet. Ian happy to be registered in this forum 🙂
Darvin is offline
post #2 of 11 (permalink) Old 02-28-2020, 07:29 PM Thread Starter
Darvin's Avatar
I have a question:
Do you know the name of this plug / connector?
ID:	167535   Click image for larger version
Darvin is offline
post #3 of 11 (permalink) Old 02-28-2020, 07:49 PM
Welcome From Canada
https://www.kawasakiversys.com/forum...ber-intro.htmlplease read, please do a second post in this thread you started( if you haven't done so). Thanks ( FYI I have this saved in my messages, every new member gets this , 1, two or even 3 post new members,
FYI you have found a extremely active and knowledgeable forum. so 2 posts or more )
post #4 of 11 (permalink) Old 02-28-2020, 08:07 PM
Fog Light Connector?
Originally Posted by Darvin View Post
I have a question:
Second look, possibly the auxiliary relay power socket. It should explain the the owners manual page 71, pretty dismal , crap photo.
https://www.partzilla.com/product/kawasaki/26031-2337 many places selling 26031-2337 , complete harness for under $5. https://www.kawasakiversys.com/forum...57-post15.html
this is the thread;
https://www.kawasakiversys.com/forum...ux-lights.html
post #5 of 11 (permalink) Old 02-29-2020, 05:47 AM Thread Starter
Darvin's Avatar
I have a question:
this is the thread;
Thank you onewizard!!!
This helps me alot.
But somehow I still have a few (maybe dumb) questions.
Why do you need the relay, is there anything wrong with it when I directly connect the lights to the connector?
My thought was, that the relay is used if you want to get more Current without damaging any other electricity or so.
Darvin is offline
post #6 of 11 (permalink) Old 02-29-2020, 10:25 AM
This helps me alot.
Again I am not sure about that photo, however the wiring is the same on all Versys , 650 and V1000, the relay interrupts the connected load when you key off. The live wire in that socket if there is one ( if this is the auxiliary power socket up near the ignition key switch ) is from the auxiliary fusing, it is live all the time, a additional circuit is in that plug which triggers the relay so when you key off the load you connected turns off. Say you added LED lights keeping within the current rating and you added a waterproof toggle switch, and advantage would be you could have lights on at night with the key removed, say for setting up a campsite. Also it would be obvious that once keyed off you would have the load still draining the battery as a reminder to turn off.
post #7 of 11 (permalink) Old 02-29-2020, 01:22 PM
aboard!
post #8 of 11 (permalink) Old 02-29-2020, 08:32 PM
aboard.
post #9 of 11 (permalink) Old 03-05-2020, 10:13 AM Thread Starter
Darvin's Avatar
This helps me alot.
Yes, but I want it only to be toggled on when it's keyed. Here in Germany we have funny people who think they are cool if they turn on the light an then when I come back my battery is empty. 😕
So, the only way is to buy this Relais?
It's about 30€ in Germany but I think it's ok.
Thx for welcoming & helping 😉
Greets from Deutschland
Darvin is offline
post #10 of 11 (permalink) Old 03-10-2020, 04:07 PM Thread Starter
Darvin's Avatar
So, I have now ordered an dual USB charger with relay kit and installed it today. It was around 30€.
I have removed the original 12V port and replaced it with the usb.
Also, I have cut the wire from the USB charger and connected it with a switch to my fog light.
Work time with soldering: 5 hours.
Thanks for helping
Darvin is offline
post #11 of 11 (permalink) Old 03-10-2020, 08:37 PM
JimK's Avatar
Hi from Jim-is-me .
[B]Once you go PACK you never go back
JimK is offline
