Howdy From Australia - Versys 650 2012 Rider - Kawasaki Versys Forum
post #1 of 6 (permalink) Old 01-25-2020, 05:43 PM Thread Starter
Question Howdy From Australia - Versys 650 2012 Rider
Howdy All,
Joined to chat and get advice from other riders.
Specifically - I took my bike in for a service and after advising me that they replaced the rear master cylinder to fix the back break issue it sadly did not.
They are now saying it is the ABS pump module and want to charge $1750 new.
I have looked everywhere for this part secondhand as it is way to expensive new - The part is specifically for 2012-2014 Versys 650 ABS.
The sad part is i can find the 2015 model and that is $99
Does anyone have any advice if there are are brands that would fit this or have they experienced the same problem.
Kind Regards
Grant
Grant Edson is offline
post #2 of 6 (permalink) Old 01-25-2020, 05:50 PM
aboard!
post #3 of 6 (permalink) Old 01-25-2020, 07:05 PM
Welcome From Canada
https://www.kawasakiversys.com/forum...ber-intro.htmlplease read, please do a second post in this thread you started( if you haven't done so). Thanks ( FYI I have this saved in my messages, every new member gets this , 1, two or even 3 post new members,
FYI you have found a extremely active and knowledgeable forum. so 2 posts or more )
post #4 of 6 (permalink) Old 01-26-2020, 12:53 AM
aboard.
Please post your second post here in this thread your started. Thanks.
Meanwhile , drop some info on your brake problem before service and what was the actual problem with the rear brake.
post #5 of 6 (permalink) Old 01-26-2020, 12:59 AM Thread Starter
In addition to my post before:
I was getting compression in the back brake - basically it wouldn't move, you had to push down and it would very slowly go down
post #6 of 6 (permalink) Old 01-26-2020, 01:08 AM
Is there any way you can disengage the ABS.
I have 09 versys and no ABS but have seen ABS cut off switch in most bikes. so see of you can disengage the ABS.
On the same did they service you back brake and are the pistons moving freely.
