12V outlet - Kawasaki Versys Forum
post #1 of 22 (permalink) Old 02-12-2013, 12:19 AM Thread Starter
Question 12V outlet
Hello!
I ordered a 12V outlet for my Versys. I need some advise how to connect/install it.
Allan
Allan K is offline
post #2 of 22 (permalink) Old 02-12-2013, 05:53 AM
I assume you ordered factory parts so I cant help you out.
Here is what I did...
http://www.kawasakiversys.com/forums...462#post159462
post #3 of 22 (permalink) Old 02-12-2013, 09:18 AM
Mine is a Powerlet BMW-size plug. I cut a hole in the dash, right side, and ran wires back to a Fuzeblock so it's switched with the ignition. It's convenient having the plug up front where you can see it.
If I were to do it again, I would at least consider getting a bar-mounted plug like in the photo...no cutting and I could take it off and use it on another bike if I ever sold the Versys.
[SIZE="1"]Ride. Good.
2019 F750GS
2014 R1200RT
2008 Versys (SOLD 11/19)
2003 ST1300ABS (SOLD 5/15)
post #4 of 22 (permalink) Old 02-12-2013, 09:21 AM
Is there a bar mounted usb version?
post #5 of 22 (permalink) Old 02-12-2013, 09:28 AM
BLACK DOG's Avatar
s&w motech has a handlebar mounting bracket
you can see it at the third place my money goes...twisted throttle
BLACK DOG is offline
post #6 of 22 (permalink) Old 02-12-2013, 09:44 AM
Do you have a link for the usb version?
post #7 of 22 (permalink) Old 02-12-2013, 10:07 AM
BLACK DOG's Avatar
it appears that they only list a lighter socket mounting bracket & you would have to come up with your own socket. wouldn't it be easier to run a tapp-lite usb power cable? it seems to be a clean & simple setup.
post #8 of 22 (permalink) Old 02-12-2013, 12:03 PM
I have the tapp-lite USB cable on both my bikes, love it. Can run my GPS or recharge my iphone, very practical.
Kawa007 is offline
post #9 of 22 (permalink) Old 02-12-2013, 12:18 PM Thread Starter
Yes, I ordered the factory parts.
Allan
Allan K is offline
post #10 of 22 (permalink) Old 02-12-2013, 12:53 PM
I just pop this into the cig socket when needed. http://www.powerlet.com/product/usb-...te-adapter/466 It's in good and tight so you don't need to worry about it working loose. I've bought cheaper brands but they were just crap....
Other places like amazon and revzilla carry them at a little cheaper price. I have 4 Cig Outlets on my bike so i can just use it on any of them...
post #11 of 22 (permalink) Old 02-12-2013, 01:05 PM
Bought the ones Cycle Gear is selling for $9.99, and mounted it to the right of the speedo, wired thru a Fuzeblock FZ-1.
ID:	16744   Click image for larger version
post #12 of 22 (permalink) Old 02-12-2013, 01:10 PM
Whats the toggle switch for?
post #13 of 22 (permalink) Old 02-12-2013, 06:27 PM
Is the 12V outlet available for the 2009? I heard that it only works on 2010 and later models.
Bergamasco is offline
post #14 of 22 (permalink) Old 02-12-2013, 06:29 PM
chid's Avatar
I installed the fuzeblock under left fairing:
http://www.kawasakiversys.com/forums...ad.php?t=18741
Versys 2015 Green
chid is offline
post #15 of 22 (permalink) Old 02-12-2013, 06:31 PM
BLACK DOG's Avatar
2010 & later have a place to connect already in the wiring harness
earlier bikes your on your own to figure out
post #16 of 22 (permalink) Old 02-15-2013, 12:38 PM
It normally mounts behind (inside) the left cowling. Nothing special to do if you have a 2010 or later. Did you buy the relay kit that goes with it?
down_on_two is offline
post #17 of 22 (permalink) Old 02-15-2013, 10:42 PM
Yeeks..... that's too bad.
post #18 of 22 (permalink) Old 02-16-2013, 12:20 AM
BLACK DOG's Avatar
It's only bad if you have no skills, then you just come to the group and call for help.
post #19 of 22 (permalink) Old 02-17-2013, 02:37 PM
Joseph - for LED running lights which will be installed... soon....
Pulled the "HOT when Ign is ON" (for the 'switched' circuits) from the tail-light, and regular 12v from the battery.
post #20 of 22 (permalink) Old 02-17-2013, 03:40 PM
[QUOTE=fasteddiecopeman;231049]Joseph - for LED running lights which will be installed... soon....
