SHAD 3P System K0VR68IF mounting problem - Kawasaki Versys Forum
 1Likes
  • 1 Post By Kristjan Valk
post #1 of 6 (permalink) Old 07-26-2019, 06:20 AM Thread Starter
I know it is the new members area but I'm in a pinch right now so perhaps someone can help me out. I have the SHAD SH23 cases and the K0VR68IF mounting kit which is perfectly listed as compatible with Versys 650 15-19.
Now if you look at the PDF instructions, the pictures do not seem like exactly the 2019 Versys. And the actual problem is that there is no such place and hole for the rear mounting point.
Anyone ever mounted these? As I cannot post links, if anyone wants to take a look at this, please go to shad.es and select bike in upper right corner and you'll get the products and the PDFs.
Kristjan Valk is offline
post #2 of 6 (permalink) Old 07-26-2019, 10:20 AM
Welcome From Canada
https://www.kawasakiversys.com/forum...ber-intro.html please read, please do a second post in this thread you started( if you haven't done so). Thanks
post #3 of 6 (permalink) Old 07-26-2019, 12:44 PM
aboard!
Originally Posted by Kristjan Valk View Post
...Now if you look at the PDF instructions, the pictures do not seem like exactly the 2019 Versys. And the actual problem is that there is no such place and hole for the rear mounting point....
I don't have time to remove my seat to check, but I seem to remember that mounting point. Did you remove your seat?
post #4 of 6 (permalink) Old 07-26-2019, 04:34 PM Thread Starter
Okay so I was finally able to mount it. It goes on top of the passenger grab rail rear mounting point with a longer bolt. But the instructions SHAD gives you are invalid. You cannot just slide it in from the side, you'll have to remove the plastics that wrap around the seat. Then you can slide in the SHAD 3P system and fasten the bolts, then reinstall the plastic bodywork.
kardan likes this.
post #5 of 6 (permalink) Old 07-31-2019, 04:32 AM Thread Starter
... please read, please do a second post in this thread you started( if you haven't done so). Thanks
Understood.
post #6 of 6 (permalink) Old 07-31-2019, 05:08 AM
aboard.
