Versys oil leak - Kawasaki Versys Forum
post #1 of 5 (permalink) Old 10-06-2012, 02:02 PM Thread Starter
Versys oil leak
My V has now done 96000 km. Still in an excellent condition. However, I have noticed drips of engine oil underneath the engine on the left hand side. It is just in front of the gear lever, but underneath the engine. Could it be coming from the drive shaft and run down to underneath the engine? I am struggling to find the source and would appreciate any suggestions. Thanks.
pduphj is offline
post #2 of 5 (permalink) Old 10-06-2012, 06:42 PM
Do you have an algaard skid plate on the bike? If so, there was a case of someone putting a hole in the oil pan when he hit an immovable object with his algaard skid plate. Even without the skid plate it's possible there's a crack in the oil pan somewhere (do you ride rough roads?). With that much mileage no doubt you know the bike well enough to rule out chain lube being flung forward. I would give the underside of the bike a good cleaning with soap and water, leave it overnight and look the next day for where the drip of oil is originating.
Mt. Versuvius is offline
post #3 of 5 (permalink) Old 10-06-2012, 08:51 PM
This is not chain oil? Has your oil level dropped?
post #4 of 5 (permalink) Old 10-07-2012, 12:15 PM Thread Starter
It is definitely not chain lube/oil. I also initially thought that it just excessive chain lube frunning down, but it is definitely not coming from the chain. It is only a few drops and does not affect the oil level. Thanks for the reply. Regards
pduphj is offline
post #5 of 5 (permalink) Old 10-07-2012, 12:28 PM Thread Starter
Thanks so much for the reply. I do not have skid plate and use it on tarmac only. The oil drips do not form when the bike is not running. I will clean it and let the bike idle until the fan comes on and then do another inspection. I am not sure if the drive shaft has an oil seal, but will also remove the front engine sprocket to see if I can spot the course. Regards
pduphj is offline
