Additional set of LED blinkers - Kawasaki Versys Forum
 1Likes
  • 1 Post By jpd
post #1 of 7 (permalink) Old 04-07-2018, 10:05 AM Thread Starter
Hi all,
I have a 2013 versys 650L and I'm trying to setup an extra pair of lights; LED blinkers parallel to the OEM filament blinkers that exists. But the LED lights doesn't light up.
Is there a way to do this keeping the OEM bulbs? Please see the attached diagram.
Also I tried replacing the original flasher relay with a LED flasher relay but didn't work for the LEDs.
Can you please help.
Thanks.
cpbravo is offline
post #2 of 7 (permalink) Old 04-07-2018, 01:18 PM
Welcome From Canada
to the forum , please read;http://www.kawasakiversys.com/forums...ber-intro.html
I have both led flasher and led signal lights , just like what you are trying to do. I will edit my post later and include photos.
First unless you spliced into the wiring going directly to the signal lights positive, your circuit won't work. As to a flasher I bought 2 styles, both less than $5, both 3 wire, ground, positive supply and signal, which actually goes to the signal light switch emergency flasher switch on the bars. I used a relay for each direction as I have led running lights as well and wanted the side with the flashing signal light to alternate the running light on that side, so I needed a normally closed contact and a normally open contact for each direction.
In this photo the right hand signal is on and the yellow led on the Barkbuster is on
here is the same side showing during the off cycle of the right hand turn
here is the running lights after cancelling the signal
FYI I have a Compu Fire regulator with the headlight relay circuit triggered off the brake light, so even though the bike is running here, the headlight is off, until a momentary brake occurs, then it latches on and remains on.
And finally my latest set up with the Denali running lights at high beam, and low beam on ( low beam is a led, which I am not happy with due to poor beam spread)
post #3 of 7 (permalink) Old 04-07-2018, 03:24 PM
jpd
Led have to be wired correctly positive to positive negative to negative. They will not light if hooked up backwards. Try to reverse your wires and see if it works
Jeff
jpd is offline
post #4 of 7 (permalink) Old 04-07-2018, 05:18 PM
aboard!
post #5 of 7 (permalink) Old 04-08-2018, 12:00 AM Thread Starter
Hi all,
Thank you so much for your replies.
Thanks @onewizard. Your bike looks amazing.
@onewizard , @jpd I followed your instructions and swapped the wires. Now they are working perfectly.
Thank you @fasteddiecopeman good to be here.
cpbravo is offline
post #6 of 7 (permalink) Old 04-08-2018, 12:13 AM Thread Starter
Hello from Ozzy
Hi all,
I'm new to the 650cc range and glad I entered to it with my 2013 Kawasaki Versys 650L.
Been riding on weekends and put some 10000kms on ODO since I bought it.
Thanks.
ID:	149865   Click image for larger version
ID:	149873   Click image for larger version
ID:	149881   Click image for larger version
cpbravo is offline
post #7 of 7 (permalink) Old 04-08-2018, 12:17 PM
Nice bike. Welcome to the Versys and Gen 2 family. Take a look at my garage photos and see what I've done with LED signals.
Tags
led lights, wiring
