Off Road Tires? - Kawasaki Versys Forum
post #1 of 11 (permalink) Old 02-19-2018, 12:46 PM Thread Starter
Off Road Tires?
I am new to the forum and I am looking for any input on off road tires for the 2017 X300. The stock tires are great on the road but we want to ride some dirt roads near home and when we travel. The stock tires are acceptable but we are looking for more grip. I heard that the Continental TKC 80 are good options but wondered if anyone has tried them. Any feedback would be appreciated.
DaleErskine is offline
post #2 of 11 (permalink) Old 02-19-2018, 04:23 PM
Check out Shinko E705's...........not sure if they make the "right" sizes for the 300.
Duffy is offline
post #3 of 11 (permalink) Old 02-19-2018, 05:34 PM
This review compares the E705's & TKC's:
. Also check out this adventure tire review from Revzilla:
. There's also a dual-sport review:
. The Heidenau K60 is also a consideration.
fgaston is offline
post #4 of 11 (permalink) Old 02-20-2018, 09:39 AM
post #5 of 11 (permalink) Old 02-20-2018, 12:41 PM
aboard!
I've run the Shinko E705s (SEVERAL sets) and TKC 80s on my Vs. BOTH work great IMHO.
post #6 of 11 (permalink) Old 02-20-2018, 02:28 PM
Eviltwin's Avatar
Has anyone here run the Avon Trailriders?
Eviltwin is offline
post #7 of 11 (permalink) Old 02-21-2018, 12:14 PM
I've also run several sets of Metzler TOURANCE rubber, and that's on V 650s.
post #8 of 11 (permalink) Old 02-21-2018, 07:18 PM
I've run Trailriders. I had excellent results on asphalt, less so on gravel. Admittedly, I was relatively new on the V at the time and didn't play with pressures - so could be better on gravel than I was capable of experiencing. I believe they're a 90-10 tire. They make Trekriders now too, which I might have tried instead for better gravel manners.
All depends on the roads you ride, but IMO a very good tire/brand choice for the V, though a bit spendy.
Put 3,000 miles on them before switching to knobs, but probably 75% tread left, no odd wear, so on the shelf for the next big road trip.
Ride more, bitch less - secret to good life!
PHX_Joe is offline
post #9 of 11 (permalink) Old 02-22-2018, 08:37 AM
Joe: what knobbies did you go with, and can I presume this was on Versys-X 300 or 650? I just ended up buying Shinko 804/805's because the trails I want to ride are almost 100% sand in SC, and I need to ride 1 hour in comfort to get to them. The good 70/30's and some 50/50's just didn't seem to have good reputation in sand.
fgaston is offline
post #10 of 11 (permalink) Old 02-22-2018, 09:20 PM
I run the common TKC80 front and E07 rear, well tried and tested by others here. I've got close to 6,000 on the set and I would say 50%+ left, I'm about 180# fully geared. I've got a gen 2 650. I lust after your wheel combo.....
FWIW, I can tell you from an ADV training session where we had a 500ft sand pit to learn in, full tire pressure (mid-30s) and I couldn't keep the bike upright more than 50'. Drop the pressure to low 20s, rode like a champ with the 'secret' to sand - drag the rear brake just a bit - and made the entire pit back and forth with minimal difficulty and no drops except the U-turn. Of course, you have to carry some form of inflator.
Dragging the rear brake works to get the bike to behave in any loose stuff, but saves my butt in sand.
Second FWIW comment - I've run the TKC80/E07 combo harder on the asphalt twisties than I ever did the trailriders, and I've yet to approach a loss of control moment due to grip. The Shinkos get pretty great reviews, so you're probably going to be happy.
Have you ridden a 650 V? Would you swap to either if you could? Considering a lighter bike for the rougher stuff, attracted to the V300x but love the HP of the 650....
PHX_Joe is offline
post #11 of 11 (permalink) Old 02-24-2018, 03:14 PM Thread Starter
Thanks very much for the info and the links.
