Thoughts.. - Kawasaki Versys Forum
post #1 of 13 (permalink) Old 07-06-2012, 12:00 PM Thread Starter
Snownut's Avatar
Thoughts..
Hello! I am not at the moment a Versys owner but am looking at one currently.. I have been searching and browsing through this forum getting as much information as I can and have a Lime Green V in my crosshairs.. I have a few questions for some of you current owners however. I just purchased a Goldwing, I have an 09 KLR, and just sold a Vstrom DL1000.. I am trying to get my wife to ride with me more and the Goldwing seems to be working, but I am having a hard time justifying 3 bikes.. I sold my Vstrom and have my KLR up for sale currently thinking I will pick up a 650 Vstrom or Versys as a good middleweight solo bike. I commute 65 miles a day and want something I can use for work or jump on for a solo canyon ride or run to my cabin which is about 2hrs away with three miles of dirt road leading up.
After browsing around on info for the Versys the only things I am really curious about are the stater output and suspension. I am in information systems and haul computers (small) and equipment around on my KLR with Pelician (caribou) side cases. I am also 235 lbs and am wondering if I would need to address the rear suspension? Also I run to my cabin after work and sometimes ride home after dark. I would like to add extra lights and would also like to have my Gerbring heated gear (insoles, vest) wired in along with my Zumo GPS and handlebar heaters.. Am I going to run into problems with draw? It seems like the Versys is a little shy on electrical output..
I have run across an 09 Lime Green with 395 miles that obviously hasn't been used much and feel like I could pick it up for a good price, are there any issues with an 09 that I should be aware of?
Thank you for any advice..
Snownut is offline
post #2 of 13 (permalink) Old 07-06-2012, 12:19 PM
Skeeter84's Avatar
I think the suspension will be fine if solo. I pack my sea horse cases and a 70 liter duffle on my solo touring trips.
Electrically that is quite a bit to run. You would want to sit down and calculatea full power draw. I would definitely find low draw lights to ease the power draw. If i remember reading correctly the wee has an even weaker charging system.
2008 Red Versys 16k miles
*Givi Windscreen*SW-Motech Evo Rack*Seahorse 720 Cases*Seat Concepts Seat*HID Headlight
1975 Honda CB200T
1976 Volkswagen Bus
Skeeter84 is offline
post #3 of 13 (permalink) Old 07-06-2012, 12:36 PM Thread Starter
Snownut's Avatar
Thanks for the reply.. 07 and newer Wee's are 400 watt, and from what I've seen on this site the Versys is about 340.. I will sit down and figure out what max draw would be tonight.. I have been looking at the 10w led lights.. How do you like your oem headlight?
Snownut is offline
post #4 of 13 (permalink) Old 07-06-2012, 01:23 PM
Skeeter84's Avatar
I think the OEM high beam is fine but i hated the low beam even after proper adjustment strained my eyes. I upgraded to a 35w 5k HID conversion. The HID conversion does have some scatter but I have been satisfied with it.
1975 Honda CB200T
1976 Volkswagen Bus
post #5 of 13 (permalink) Old 07-06-2012, 02:51 PM
post #6 of 13 (permalink) Old 07-07-2012, 08:04 AM Thread Starter
Snownut's Avatar
Thank you! If all goes as planned I should have a lime green V in my garage tonight..
Snownut is offline
post #7 of 13 (permalink) Old 07-08-2012, 01:48 PM Thread Starter
Snownut's Avatar
Well, I did it.. Add one green machine to my stable.. Found this 09 with 367 miles for a very bargain price...
[IMG][/IMG]
Snownut is offline
post #8 of 13 (permalink) Old 07-08-2012, 02:17 PM
Snownut - you have a ONE-OF-A-KIND green Versys. The green ones came with black frame, rims, forks, etc, so looks like someone changed over blue body bits for green.
ID:	15156   Click image for larger version
post #9 of 13 (permalink) Old 07-08-2012, 02:20 PM
Sprocket's Avatar
I run heated gloves and a heated liner with no issues. I don't really see much point in insulated pant liners or boot soles though with insulated motorcycle pants and I ride down to 32F. I'm comfy in the cold with just Rev'It Sand pants over long underwear and Goretex lined boots on my lower half. You can make your heated gear a lot more comfortable and energy efficient in the cold by wearing a layer of insulation, like the standard insulated jacket liner, over top of it. Most heated gear, at least Gerbings has no real insulation so needs to be run on max which produces hot and cold spots in cold weather - unless you wear some insulation over top. Doing this you may find you have enough power for the pant liners and soles too.
Sprocket is offline
post #10 of 13 (permalink) Old 07-08-2012, 02:30 PM Thread Starter
Snownut's Avatar
Ive actually been confused with the silver.. I have never seen a photo of one with the silver rims and forks.. The original owner bought it this way from the dealer.. I have wondered if the dealer swapped out the color with someone who possibly wanted blue with black.. I don't mind the color scheme.. Any idea if one could determine from the vin what color the bike should be?
Snownut is offline
post #11 of 13 (permalink) Old 07-08-2012, 02:33 PM Thread Starter
Snownut's Avatar
I wear insulation over my gerbrings and rarely run the heat more than 1/2.. I have low blood pressure and my feet seem to always be cold so the heated insoles cure that problem.. Legs aren't in issue, but Ive found if my toes, hands and chest is warm I can ride in any temp..
Snownut is offline
post #12 of 13 (permalink) Old 07-08-2012, 07:50 PM
The original colour should have been a Blue- IMHO.
post #13 of 13 (permalink) Old 07-08-2012, 07:57 PM Thread Starter
Snownut's Avatar
From everything Ive read I tend to agree with you.. I do have the original dealer docs and they all reflect green as well.. It would be interesting to find out how it ended up the color scheme it did.. I have talked to the original dealer in the past and know a salesman well enough I am going to give him a call tomorrow to see if he might recall..
09 Lime Versys
13' DL650 Vstrom
06 (Gold) Goldwing IV
Snownut is offline
