Turn Signal Connectors - Kawasaki Versys Forum
 3Likes
  • 1 Post By Gigitt
  • 1 Post By redden68
  • 1 Post By Motojunkee
post #1 of 8 (permalink) Old 12-03-2016, 01:01 AM Thread Starter
sking41's Avatar
I purchased a new set of turn signals for my 2009 versys and the new set of turn signals didn't come with any connectors on the wires.
I am having a hard time removing the "male" connectors off of the old turn signals to place on the new turn signals. Do I need to buy new connectors? If so, where can you purchase them?
Last edited by onewizard; 12-03-2016 at 12:50 PM. Reason: Corrected spelling Conector , for tools/ search function/ search post "connector"
sking41 is offline
post #2 of 8 (permalink) Old 12-03-2016, 07:15 AM
BLACK DOG's Avatar
wire cutters
heatshrink tubing
soldering iron
Seems to me that any other way will eventually fail or just look sloppy
JMO
BLACK DOG is offline
post #3 of 8 (permalink) Old 12-03-2016, 07:47 AM
Most electrical connections on the bike have a barb prong that locks the wire and connector into the plastic housing.
Most of the large size wires and connectors can be de-pinned (small fine wires are much harder to work with)
In your case you should be able to unplug the old turn signal, take it off the bike, then because you new turn signals only have bare wire, you will then need to snip off the old connector and join the old connector wires to to the new turn signals. Suggested method is solder the wire and user heat shrink tubing to protect the exposed joint from short circuiting.
If you are resourceful... you could try and find what kind of connector plug style is used, and buy the plastic housing and a few new connectors and crimp the new turn signal wire on - for that factory install!
Gigitt is offline
post #4 of 8 (permalink) Old 12-03-2016, 08:13 AM
Source For connectors
Somewhere on this forum are pictures and more detail. For now here is a link, you can ask them for your model year,not sure if they are the same. These are for MK-3
Motorcycle MT .090 Sealed Series - Connector and Terminals
post #5 of 8 (permalink) Old 12-03-2016, 09:43 AM
When I changed my front turn signals, I used these:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
I can solder but these are easier.
redden68 is offline
post #6 of 8 (permalink) Old 12-03-2016, 09:54 AM
post #7 of 8 (permalink) Old 12-03-2016, 02:32 PM
aboard!
post #8 of 8 (permalink) Old 01-03-2017, 05:38 AM
Motojunkee is offline
