2015 versys 650, show me the seat compartment! - Kawasaki Versys Forum
Like Tree6Likes
post #1 of 25 (permalink) Old 01-24-2016, 03:11 PM Thread Starter
Hi,
I'm about to shop for a versys 2015, but I would like to see the underseat compartments before hand, just in case.
Pictures, videos, depth, width, height if possible.
thanks.
dddd is offline
post #2 of 25 (permalink) Old 01-24-2016, 07:25 PM
It's not the best bike for smuggling!
HAWKSHOT99 and steve1503 like this.
Gigitt is offline
post #3 of 25 (permalink) Old 01-24-2016, 09:05 PM
Originally Posted by dddd View Post
Hi,
thanks.
Why not go to the dealer and ask them to remove the seat pan? You will find the area to be quite small and limiting.
blazblu82 is offline
post #4 of 25 (permalink) Old 01-24-2016, 09:44 PM Thread Starter
because dealer (the only one who has it in showroom) is too far, and we dont ride bike in winter here to go there (and no car).
I could also have said: because I want more than one person to benefit from the answer, on the net.
dddd is offline
post #5 of 25 (permalink) Old 01-25-2016, 04:22 AM
Well, if the 2015 is anything like my 2011, there isn't any room to store anything. Under seat area holds the battery, some electronics, tool kit, security lock and seat latch and that's it. The seat pan occupies most of the available space.
You could get an idea of what it looks like by going to PartZilla or Babbitts and look at parts diagrams.
This diagram here shows the rear frame area where all of what I just mentioned is stored under the seat.
Hope this helps some.
post #6 of 25 (permalink) Old 01-25-2016, 09:07 AM
No ruler Hope this helps.
lrppcer likes this.
turn8a is online now
post #7 of 25 (permalink) Old 01-25-2016, 09:10 AM
Here is another Pic.
post #8 of 25 (permalink) Old 01-25-2016, 09:24 AM Thread Starter
Actually not much; you didn't empty the compartments first! LOL.
And the resolution (was that a 2007 cell phone...!) and lighting are so bad I have no clue what's what, like the rounded shiny piece...
Thanks anyway for the effort.
The question I'm trying to answer is if that can hold my old gorilla 8017 alarm system (3.6"x3.1"x2").
Or at least the 9100 unit (2.75 dia x 1.5") Gorilla Cycle Alarms - Quality Motorcycle Alarms
The rest I can relocate (even the tools' pouch, altough I would prefer not to).
dddd is offline
post #9 of 25 (permalink) Old 01-25-2016, 10:10 AM
iPad mini. Probably the best I can get you. I struggle just to turn the thing on and off.lol
post #10 of 25 (permalink) Old 01-25-2016, 07:12 PM
rounded shiny piece is cover for electrical conections,,,,
royinspain is offline
post #11 of 25 (permalink) Old 01-25-2016, 07:30 PM
3dog's Avatar
There is a great picture in this thread regarding power distribution blocks by Motojunkee here
Mel
__________________________
2015 Versys 650 ABS "Kermit"
3dog is offline
post #12 of 25 (permalink) Old 01-25-2016, 09:29 PM
people do you a favor and you thank them by those comments? Good luck with that.
scutrbrau likes this.
post #13 of 25 (permalink) Old 01-25-2016, 10:20 PM
My 2009 didn't have an issue with my Scorpio I900 alarm. Dimensions are listed.....Scorpio SR-i900 Security System - RevZilla
post #14 of 25 (permalink) Old 01-25-2016, 10:43 PM Thread Starter
Actually, you probably need luck more than I do, because the way you read suggests you misinterpret negatively most posts. My answer was perfectly fine and teasing.
dddd is offline
post #15 of 25 (permalink) Old 01-25-2016, 10:47 PM Thread Starter
So, from what I can tell is that there is simply no room at all...
Sigh.
I prepared foam dummies of the target sizes and I will eventually go see the bike, perhaps during an upcoming show downtown.
thanks for the pics!
dddd is offline
post #16 of 25 (permalink) Old 01-25-2016, 11:31 PM
Or at least the 9100 unit (2.75 dia x 1.5") [url=http://gorillacyclealarm.com/9.features]Gorilla Cycle Alarms - ).
I have added a considerable amount of stuff then removed it--------------------so the 8017 is the 2 inches the depth?
9100 the 2.75 inches diameter may fit on the left side under the plastic--is this alarm encapsulated ( waterproof)
I have a 07 , presently on a bike lift and covered up, but I could check once I know.
post #17 of 25 (permalink) Old 01-26-2016, 09:42 AM Thread Starter
sure, why not.... doesn't matter.
If you meant in the seat cowling, then I hope it can be secured in place. Yes it is waterproof.
dddd is offline
post #18 of 25 (permalink) Old 01-26-2016, 10:05 AM
I manage to squeeze in a small medkit, a Leatherman multitool and a cargo net. If I don't align those things perfectly, the seat doesn't close, so it's about as much as you can reasonably expect to fit.
2015 Versys 650
_Big_Mac_ is online now
post #19 of 25 (permalink) Old 01-26-2016, 12:00 PM
On my 2008 V, there is a huge empty space under the cowl on the left side of the fuel tank. I put a horn relay in there, with lots of room left over.
There is also lots of room under the speedometer, behind the headlight.
trialsguy is offline
post #20 of 25 (permalink) Old 01-26-2016, 12:52 PM
Room Under seat--Tool storage area
So I added some 3/4 spacers under a 2X4, giving a thickness of 2.25 inches, I have a 07 with a Corbin seat. The 5.5" dimension has a additional 3/4 " so 6.25 would also fit.
Picture 2 shows the red terminal to the left of , which is the battery, between the battery and compartment you will notice a tube running across, I have some 3/16 rubber wire tied in place to support the Corbin seat and prevent it from shifting side to side.
Picture 3 shows some white 3/4 foam in a storage area directly in front of the ECU, I doubt you would get anything 1" to fit, but you could put your tools here, one at a time, also the strap goes the long way, so you would need a second means of securing the tools if stored here.
Picture 4 is my brake flasher / Addmore lighting connections and trigger connection for the headlight relay, very top you will notice several wires, I added a longer stud and this is my frame ground with additions.
Picture 5, I added the 3/4 foam to the end of the 2X4 to show the additional room.
Last, I very much doubt the 2015 is different from this. As to the alarm system, this would be the ideal location-------wrong again, well I tried
Best to read Eddie's next post
ID:	79017   Click image for larger version
ID:	79025   Click image for larger version
ID:	79033   Click image for larger version
ID:	79041   Click image for larger version
