400 conversion - Kawasaki Versys Forum
Like Tree4Likes
  • 1 Post By fasteddiecopeman
  • 2 Post By RobMontana
  • 1 Post By crankshaft
post #1 of 9 (permalink) Old 03-30-2020, 10:24 PM Thread Starter
Bulldogdaddy's Avatar
400 conversion
the 300 versys is a very nice bike but it would be awesome with a 25,% power boost. has anyone heard if it is possible to transplant a 400 ninja engine in the sweet little 300.i am asking because i may be able to get such a donor engine but if its known to be impossible i will pass.
Bulldogdaddy is offline
post #2 of 9 (permalink) Old 03-31-2020, 07:20 AM
Interesting, not sure such a job undertaken so far, maybe others will chip in.
post #3 of 9 (permalink) Old 03-31-2020, 08:26 AM
I'm sure you can make a determination by looking at the mounting points of the two engines.
Are you going to get the throttle bodies and ECU and all the other bits to do a complete conversion? If you get everything you need and then find out that it won't fit, I'm sure you can resell for someone wanted to do a cart or fit one in a KLR frame.
post #4 of 9 (permalink) Old 03-31-2020, 01:59 PM
It would definitely reduce the KLR's weight, AND produce about 10 HP MORE!!!
Tcruarceri likes this.
post #5 of 9 (permalink) Old 03-31-2020, 02:15 PM
There is a less than scientific photo comparison in this article of the size of the 300 vs 400 motor. Looks like the head is slightly larger, and the sump is longer and wider. Dropping one of these into a X-300 or KLR frame sounds like a great project, good luck!
Ninja 400 Article
asphaltaddict33 is offline
post #6 of 9 (permalink) Old 03-31-2020, 08:21 PM
RobMontana's Avatar
The 300 is great as is! Its not a racing bike. It will do 100 mph. But you shouldn’t be going that fast, ever. It is light, fun, and versatile!
A 400 motor will get you 5 or 6 more horsepower and add a few pounds. Makes no sense to me to do all that work for little practical gains. Yeah you may go a little faster but speed limits on the streets negate that. And off-road I’ll take the lighter 300.
TexH and east10icn like this.
RobMontana is offline
post #7 of 9 (permalink) Old 04-02-2020, 03:27 PM
The 400 motor does not fit in the frame - it's completely different.
crankshaft is offline
post #8 of 9 (permalink) Old 04-15-2020, 09:38 PM
If you happen to need any details or measurements from the Ninja 400, I have one. You might need to @ me or email me since I’m fairly infrequent in visiting this forum.
Rkturbo is offline
post #9 of 9 (permalink) Old 04-25-2020, 11:57 AM Thread Starter
I had my local kawasaki mechanic compare the two engines and would require a lot of fabrication so she shall remain a 300 for her lifetime.
