ER6N blinkers under racks - Kawasaki Versys Forum
post #1 of 9 (permalink) Old 07-19-2010, 08:17 PM Thread Starter
Jake's Avatar
Well got the idea from a member over on advrider.com Looks like the euro er6n blinkers are 10 cm where as the versys blinkers are much longer making them need to be reloaced during the givi rack install. I hate the relocation so i'm trying to get ahold of some of the blinkers to use. I believe they will work, but i'll never know for sure untill i get some or get them on. So has anyone over here swapped there rear blinkers to fit inside the rack in the stock location? Anyone have an us spec er6n that they could mesure the factory blinkers for there length?
Jake is offline
post #2 of 9 (permalink) Old 07-19-2010, 08:42 PM
brothercannon's Avatar
um, there is an er6-n sitting right next to my Versys with with Givi luggage and racks on it. Now I need the motivation to go out there and measure.
brothercannon is offline
post #3 of 9 (permalink) Old 07-19-2010, 10:28 PM Thread Starter
Jake's Avatar
Would be great if you could give them a measure. Here is what i came up with:
Here are the racks i'm dealing with:
And Givi's horible relocation idea:
Versys factory blinkers, looks like a tad under 5":
About the gap i'm working with, i say about because there is a spacer on the Givi reloaction stuff so i'm looking at about another 1/16" Looking about 4 1/4"
Jake is offline
post #4 of 9 (permalink) Old 07-27-2010, 09:55 PM
I gave the blinkers a quick look over this evening. I only used my hand as a measurement tool but it looks like the they are the same size in length if not a tad longer. I'll try to remember to snap a few quick pics tomorrow.
post #5 of 9 (permalink) Old 08-03-2010, 09:36 AM
Sorry it took me so long but here is a pic of an ER-6n rear turn signal.
post #6 of 9 (permalink) Old 08-04-2010, 04:08 PM
I never bothered to relocate my turn signals when I installed my V35's. As with you I did not like the look of the adjustment and since I tend to ride mostly without the luggage on I did not want the permanent change to the turn signals. Instead I bought the Admore lighting kit for the luggage so I don't need to worry about people seeing my turn signals.
The stock turn signals just barely touch the back of the cases when they are on which is not a big deal.
emur is offline
post #7 of 9 (permalink) Old 08-04-2010, 05:05 PM
Thumper's Avatar
I'm confused (Not that hard at my age) . I have Givi racks and my relocation has a mounting bracket. Does not look bad IMO. Here are some pics and where I drilled a small hole to run the wires. The only difference I see between the two is I am using Caribou bags instead of V35 (I guess).
Your relocation looks different?
IBA #23562
Thumper is offline
post #8 of 9 (permalink) Old 08-04-2010, 05:39 PM
The Givi racks and relocation brackets are different on the older V's.
post #9 of 9 (permalink) Old 08-04-2010, 05:47 PM
Thumper's Avatar
OK, thanks for clarification.
IBA #23562
Thumper is offline
