Tv wall bracket to Fender Riser - Kawasaki Versys Forum
post #1 of 3 (permalink) Old 11-29-2015, 06:15 AM Thread Starter
BKKPhil's Avatar
I have seen a few mods on the versys for lifting the front, some which exposed brake lines which I find odd and unsafe. Mine has plenty of space while still protecting the lines.
I have just fitted the Heidenau K60 rear to my motorcycle which is a 140/80/17 which sat nicely, however the front requires the fender to be lifted to accommodate this size. This is how I did it.
Wondering what I could use having seen a mod in a kawasaki versys forum I stumble upon an unused LCD TV wall bracket 22mm wide. With slots already in place to make adjustments to the height of the TV, I got to work and cut it to suit the bike.
Please note I didn't use the tile/stone cutter in the picture.
Flattened off any raised edges from the original bracket shape.
Offered it up to the bike fender brackets.
I then ground the head of a bolt flat, to tuck behind the bracket leaving enough to bow on the bracket I made so that it clamped it to the bike to prevent it from spinning.
BKKPhil is offline
post #2 of 3 (permalink) Old 11-29-2015, 06:17 AM Thread Starter
BKKPhil's Avatar
Slotted the bolt behind the bracket and cut the threads to the required size.
A quick coat of paint and job done. No fancy measurement needed with it being slotted. Total time including paint drying 2 hrs approx.
Plenty of space for the K60 front which I hope will be fitted mid week. Additionally, the fender is now adjustable and can be lowered if I put standard tires back on.
BKKPhil is offline
post #3 of 3 (permalink) Old 11-29-2015, 01:00 PM
NICE work...!
