Acerbis Guards with Light Unit - Kawasaki Versys Forum
post #1 of 9 (permalink) Old 11-09-2015, 09:49 AM Thread Starter
Put these on a couple of weeks ago and am quite happy. PITA to get the light unit to set properly, but all worked out. Pics also show my aux. light and the recently replaced Aprilla knockoff mirrors.
ID:	75657   Click image for larger version
ID:	75665   Click image for larger version
rayj
2009 Versys (Mine's Green)
rayj is offline
post #2 of 9 (permalink) Old 11-09-2015, 01:30 PM
ronheater70's Avatar
I like the look of those, do you feel they are strong enough to withstand bumping into things without breaking the lights easily? Would be really cool to wire them somehow to your directional's so they blink in conjunction with the corresponding turn signal.. not sure if that's possible though .
ronheater70 is offline
post #3 of 9 (permalink) Old 11-09-2015, 04:00 PM Thread Starter
Ron, that is exactly what they do. The first pic is with the blinker not on, and the next two are shots I got were when the emergency signal was on for both of them when they were lit up. These are a lot more sturdy than what I thought they were going to be. This Dual Road model only attaches to the bar end , and has a metal frame for that area. Hope I don't have to test them, but given the fact that I have had a couple of driveway and parking lot drops, you never know. I've attached a shot looking over the throttle at the back of the guard. It also showcases those wonderful Grip Buddies I put on. I also attached two pics taken within a second of each other, one with the blinkers off, and one with them on.
ID:	75689   Click image for larger version
ID:	75697   Click image for larger version
rayj
rayj is offline
post #4 of 9 (permalink) Old 11-09-2015, 05:20 PM
kawdog's Avatar
Generally in the industry, attached on ONE end is Hand SHIELDS (for street or trail riding) and at BOTH ends is Hand GUARDS. Hand Shields should work fine and they were what I was going to get. Bur after spraining my wrist that took 6+ weeks to heal, I got the Hand GUARDS. Thank goodness a lot of experts here already had an AL racing Handguard already picked out (for $127 complete on fleabay including all brackets and flashing blinker lights on hand cover.)
Thanks Again guys! (including Fast Eddie Handguards was next accessory in importance after tall windscreen, crash bar, rear rack, and dual horns
kawdog is offline
post #5 of 9 (permalink) Old 11-09-2015, 09:26 PM
chadams66's Avatar
did you have to fabricate your own connections to the stock lighting or do they include connectors? I think you mentioned it was a bit fiddlely...
chadams66 is offline
post #6 of 9 (permalink) Old 11-10-2015, 09:22 AM Thread Starter
They came with no wire connections of any sort, and one of our learned souls suggested I do a thorough soldering job, and another mentioned that I should use the Posi-Tap connectors, which I had used to wire my Admore lights on the tail. I ordered some 18 -20 wire guage taps and connected them just to the inside of the disconnect clip for the turn signals so as not to have to remove the wiring when taking off the turn signal plastic fairing. I think these (Posi-Tap) connectors are one of the best inventions, and can't believe that none of the local or national auto parts, hardware or big box stores carry them. Amazon saves the day, and free 2 day delivery using my brides Prime account.
Name:	Posi tap pic.JPG
rayj
rayj is offline
post #7 of 9 (permalink) Old 11-10-2015, 10:40 AM
You're welcome
Agreed I could not find them anywhere locally I get mine off ebay
post #8 of 9 (permalink) Old 11-10-2015, 11:45 AM Thread Starter
I was remiss in not giving names of the learned souls. Thank you Fasteddie for the soldering suggestion, and a big THANKS to MaverickAus for the Posi-Tap suggestion. BTW, I found that the turn signal wiring was probably around an 18, but the hand guard was around a 24 or 26 gauge. I just doubled up the wire on the insert end of the tap, and was prepared to insert some "filler" wire if that was not enough to get a bite and a seal. I did tidy up with electric tape and made a waterproof shroud for the area in which the cap of the tap might be subject to the elements.
rayj
rayj is offline
post #9 of 9 (permalink) Old 11-10-2015, 03:43 PM
You are VERY for any help I was able to give...!
