Valve cap PSI indicators - Kawasaki Versys Forum
Like Tree3Likes
  • 1 Post By CamBkm
  • 1 Post By weljo2001
post #1 of 14 (permalink) Old 10-15-2015, 12:43 PM Thread Starter
kawdog's Avatar
Are there any good ones out there? From looking at the 1 out of 5 star comments on Amazon, they all look like they leak!
I knew it was too good to be true, ha ha.
A rotating red light on my wheels would have been cool, but I hear that doesn't work, just like the leaky caps don't give proper indications: good concept though IF it worked. I guess too many moving parts with variable air/rubber interfaces getting slung around the wheel constantly may be impossible to calibrate (for $3 per set of 4 anyway.)
TIA!
kawdog is offline
post #2 of 14 (permalink) Old 10-15-2015, 12:48 PM
kawdog likes this.
CamBkm is offline
post #3 of 14 (permalink) Old 10-15-2015, 01:42 PM
I tried one of these.....Amazon.com: TireGard (13-315U) Wireless Tire Pressure Monitor System: Automotive
It was a waste of money...
kawdog likes this.
post #4 of 14 (permalink) Old 10-15-2015, 02:43 PM Thread Starter
kawdog's Avatar
Wow, looks like a safety accident ready to happen. I wonder how those Mercedes Benz and BMW's with automatic air fill's are working. Oh well, THANKS!!
I guess Joe's bent AL Curvy Girl's air valve stems are the most leak proof and ergonomic solution around
kawdog is offline
post #5 of 14 (permalink) Old 10-15-2015, 02:51 PM
Their not recommended to use with rubber valve stems. I had some steel ones put on and really hoped the TPMS would do the trick but it just wasn't so.
kawdog likes this.
post #6 of 14 (permalink) Old 10-16-2015, 12:35 AM
Not recommended-Safety issues.
Fastoman is online now
post #7 of 14 (permalink) Old 10-16-2015, 05:00 AM
I bought a TPMS kit which worked fine however having to remove the sensors to pump up the tyres was a PITA so I removed them. They had a tiny grub screw holding them onto the valve stem and trying to remove it and put it back on at the servo was frustrating. Also the sensors were quite heavy and no doubt threw off the wheel balance.
So in closing if you had your own compressor, had solid valves (not rubber) and balanced the wheels after you fitted them they would probably be fine.
post #8 of 14 (permalink) Old 10-16-2015, 06:20 AM
I have the Doran TPMS system on my Voyager. You have the choice of putting the sensor on the valve stem or internal on the special valve stem that comes with the system. The monitor hard wires into the bike. Works very well.
post #9 of 14 (permalink) Old 10-16-2015, 06:29 AM
kohburn's Avatar
I've used those little turkey timer pressure indicators on cars before. never actually had one leak but did have them stop working after a few years.
kohburn is offline
post #10 of 14 (permalink) Old 10-16-2015, 02:10 PM
I like that idea
post #11 of 14 (permalink) Old 10-18-2015, 01:19 PM
Ever watch a trucker check his tires? He walks around w/ a rubber-mallet and hits each tire, looking for a different "thunk" indicating low pressure. I checked my pressures, set them correctly, than hit them to see what a correct "thump" felt like.
NOW, before each ride I hit the tires, and every couple of weeks check them w/ a tire-gauge, filling as necessary.
Works for me....
post #12 of 14 (permalink) Old 10-19-2015, 12:17 AM
TIA!
If you're looking at after market valves I would look at the 90 degree valve stems. I had these on my previous motorcycle and they make filling and checking the tires a LOT easier and quicker. When mounting they should point to the right as the bike leans to the left on the side stand.
As an example - 90 Degree Motorcycle Blue Valve Stems Tire 10mm Pair 11 3mm Suzuki GS GSX GSXR | eBay - you can find these in any color you want on EBay.
I used these in conjunction with a cheap 12V air pump that reads tire pressure.
post #13 of 14 (permalink) Old 10-19-2015, 01:29 AM Thread Starter
kawdog's Avatar
Thanks, I've got Kurvey Girls bent air valves, but saw the indicators and thought it would be good if it held air. I also wanted the spinning lights that some psi indicators have (that doesn't work also.) Air is going to leak no matter what, so any interface other than metal to metal clamping rubber is going to leak faster.
kawdog is offline
post #14 of 14 (permalink) Old 10-19-2015, 01:36 AM
as i recall you can get wireless ones that get installed inside the rim or on/replace the valve stem but im not 100% sure
