Recommend any handguards cheaper than Barkbuster Storm? - Kawasaki Versys Forum
post #1 of 18 (permalink) Old 09-22-2015, 09:45 AM Thread Starter
This is really a 2 part question. I intend to ride through the winter whenever there is no snow/ice, I would like handguards. The Barkbuster storms are great, but I'm really trying to mitigate spending and address debt right now, if there is a product that will be almost as good for less cash, I'd like to know about it.
Secondarily---as I look at the Storm's, I see them in a wide range of prices ($120-180) and also a separate mounting kit that's also around $100. Surely something like this is an all-in-one kit purchase, yes?
AdventureSeeker is offline
post #2 of 18 (permalink) Old 09-22-2015, 11:12 AM
i too looked at the barkbusters but saved a fare bit by buying kawasaki own ones from the main dealers saved 1500 baht (42 us dollars )
i looked at others but they were too short due to the brake reservoir . price was 4100 baht ( 113 us ) and they came in black or green i personally like them better and the quality is very good ,if you want i can post photo latter its night here so dark
ste860 is offline
post #3 of 18 (permalink) Old 09-22-2015, 01:46 PM
chadams66's Avatar
Barkdusters makes a cloth material handguards that sell around 110 bucks and are just one piece (I plan on buying them myself)...Barkbusters Blizzard Universal Handguards - RevZilla
Hippo Hands makes a fairly cheap hand guards...Motorcycle Hippo Hands, Handlebar Muffs
chadams66 is offline
post #4 of 18 (permalink) Old 09-22-2015, 02:43 PM
For really cold or wet weather i use these.......http://www.amazon.com/Quadboss-Handl...ords=ATV+mitts
Used them on the Versys now on the FJR when needed....
post #5 of 18 (permalink) Old 09-22-2015, 02:44 PM
whole kit $160
Barkbusters Storm Handguards for For Kawasaki Versys 650 '07-'14 - TwistedThrottle.com
post #6 of 18 (permalink) Old 09-22-2015, 02:48 PM
I run (ran...) Zeta XC guards w/ the 'drop-down' aluminum spine on my '08 (and '09). They survived a 20 mph low-side, and Amazon sells them for about $100US (AND you can have turn sigs in them for more $.
post #7 of 18 (permalink) Old 09-23-2015, 08:31 AM Thread Starter
I've seen those ATV wraps, not gonna lie, I'm afraid of them. They are interesting though.
You have to buy the bar as one piece and the guards separately, yeah? At least on Amazon?
post #8 of 18 (permalink) Old 09-23-2015, 09:18 AM
outdoorgb's Avatar
I also have a KLR with OEM handguards...great for keeping the wind off my hands in winter.
I tried to find an affordable set for the Versys for weeks, nothing really stood out. So, I also bought some mitts.
Oxford Motorcycle Mitts - $50
Oxford Handlebar Muffs for Motorcycles - TwistedThrottle.com
Great fit, no modification needed. Installs in about 3 minutes. I can access all of my controls. These will hold me over until I find some handguards I like...
I like the Bark Buster Muffs above...little more open.
I'll probably go for the Bark Buster Storms from TW in the spring after I give the muffs a try...
outdoorgb is offline
post #9 of 18 (permalink) Old 09-23-2015, 10:26 AM
I have a set of Cycra Probends on my '09. I had to get some spacers and get a little creative to get them installed, but they fit fine and work well. Not sure how they work on newer models...
Here is a link to another install thread: http://www.kawasakiversys.com/forums...installed.html
it looks like they sell in components or an entire kit with the mounts.
here's one solution: Cycra Pro-Bend Center Reach Clamp Racer Pack - Motorcycle Superstore
'18 Versys V1K
'09 Versys 650
Jmason is offline
post #10 of 18 (permalink) Old 09-23-2015, 01:06 PM
...You have to buy the bar as one piece and the guards separately, yeah? At least on Amazon?
Seems to me that I saw them BOTH ways in the Amazon ads I looked at....
post #11 of 18 (permalink) Old 09-23-2015, 01:32 PM
kawdog's Avatar
And those are lightweight aluminum racing bars too. They were made for out bikes!
kawdog is offline
post #12 of 18 (permalink) Old 09-23-2015, 03:51 PM
i have some $20 cheapys block the mind and rain quite well dont think they would bust much bark tho
post #13 of 18 (permalink) Old 09-23-2015, 11:31 PM
kawdog's Avatar
Mind blockers? Sounds interesting!
kawdog is offline
post #14 of 18 (permalink) Old 09-24-2015, 07:36 PM
wind**
post #15 of 18 (permalink) Old 09-24-2015, 09:09 PM
Would the KLR handguards not adapt to the Versys. Seems it should be easy and cheap.
blazblu82 is offline
post #16 of 18 (permalink) Old 09-25-2015, 03:20 AM
I've had handguards which I later had to remove due to installing Gaffer SS brake lines. I also do a lot of cold weather riding because of the local climate. Here's my brain dump, for what it is worth, on cold weather riding... Don't bother with hand guards, they don't have much of a noticeable effect on the warmth of your hands. Instead focus on gear. Instead invest in a good set of heated grips or heated gloves and heated jacket liner. Oxford heated grips are relatively cheap and work well, they're are also other good heated grips. Heated gloves are more expensive but warmer than heated grips and better for extended periods of riding in the cold. The downside to heated gloves is they are not as convenient as heated grips and twice the price. Heated gloves or grips and heated jacket liner are the cat's ass in cold weather (<50F to 32F). A heated jacket liner is almost essential if you are riding for extended periods, at higher speeds, in near freezing temperatures. You also need two heat controllers if you run heated gloves and heated jacket liner. Motorcycle pants are essential, jeans just don't block the wind in cold weather.
post #17 of 18 (permalink) Old 09-25-2015, 12:46 PM
Some 'inmates' here have run Suzuki V-Strom guards which just mount on the ends of the bars, so - GOOD wind protection, but VERY LITTLE impact protection.
post #18 of 18 (permalink) Old 10-06-2015, 11:42 PM
Barkbuster Storm vs Blizzard
I had a set of Barkbuster Storms on an ER6n (Ninja). I now have a set of Blizzards on my 2015 650 Versys.
The Blizzards are so much more effective that its not funny. They are also much easier to install and remove in the warmer months.
They are still not as effective as the Oxford handlebar muffs, but are easier to use. The muffs tend to foul the levers. No such problem with the Blizzards.
BruceC
bc6805 is offline
