Handguards! - Kawasaki Versys Forum
post #1 of 32 (permalink) Old 07-28-2008, 11:27 PM Thread Starter
amir_zwara's Avatar
Question Handguards!
I'd love a set, but don't know what I need.
I see most people had to do modifications to get them to fit correctly. So my question is... if I want the cheapest (but still effective) handguads, that would require the least amount of modification to get onto the bike.... what do I look for? and Where do I look?
any links, part #s, etc... would be very helpful.
amir_zwara is offline
post #2 of 32 (permalink) Old 07-28-2008, 11:39 PM
Bicyclebob's Avatar
Acerbis Rallypro II. Check them out at www.motosport.com. Just get them with the stock mounting kit.
Bicyclebob is offline
post #3 of 32 (permalink) Old 07-28-2008, 11:46 PM Thread Starter
amir_zwara's Avatar
Red face
The stock mounting kit, as in the one that comes with the handguards yes?
also, do you have these? If so do you happen to have a pic or two that I can view.
Thanks.
post #4 of 32 (permalink) Old 07-29-2008, 12:16 AM
Bicyclebob's Avatar
Correct, the ones that come with the kit. I actually use them on my dirt bike. I will take some photos tomorrow and post them for you. You may also want to use the search feature located in the top header on this page. Type in handguards. There may already be some photos posted.
Bob
post #5 of 32 (permalink) Old 07-31-2008, 08:41 AM
Bob
Bob's Avatar
saw this thread the other day but didn't have time to reply and then promptly forgot about it.
I saw these Zeta guards on the black V and I must say they look good to me.
Zeta Handgaurds
Still trying to find out where I can source them locally. I know a buddy of mine had some Zeta's on his KTM I took for a spin, but forgot to ask him where he got them from.
08' Diablo Black Kawasaki Verys
98' 3.0L V6 Colt Rodeo D/C (Engine rebuilt, Body lift, Monroe Shocks, 32" Wrangler MTR's, GME GX300)
Work hard, play harder. --Bob
Bob is offline
post #6 of 32 (permalink) Old 07-31-2008, 06:37 PM
I have the Zeta armor XC handguards with flushmounted led turn signals and love them. High quality. Here is the info where I bought them.
http://www.langstonracing.com/default.asp
Part numbers:
Zeta Armor Straight Handguards
ZE72-STRAIGHT-ARMOR
Zeta Armor Handguard XC Flasher Protector
ZE72-XCFLASHER
Li432Paul is offline
post #7 of 32 (permalink) Old 08-01-2008, 03:21 AM
Bob
Bob's Avatar
cool,
thanks Li432Paul, will go and look, and thanks for the part numbers!
Two places I mailed yesterday haven't responded yet.
Bob is offline
post #8 of 32 (permalink) Old 08-01-2008, 07:55 AM
StonedGP's Avatar
I like the KTM handguards, but didn't want to lose the vibration canceling of the bar end weights. Did anyone figure a way to mount the KTM guards without losing the weights?
StonedGP is offline
post #9 of 32 (permalink) Old 08-01-2008, 02:03 PM
I have done this. Just bought longer similar screws and "tube spacers" that I cut to the right length to put the preasure on the middle of the weight. It works ok. Here's some more info about it.
Lots of info about fitting here (also detaild info on how I fitted mine)
http://www.versys.co.uk/index.php?op...39692#msg39692
MeanGreen is offline
post #10 of 32 (permalink) Old 08-01-2008, 08:54 PM
I don't think the bar end weights do as much as you think. I installed mine without them and have had no more vibration at the bars than before.
Gustavo
Gustavo is offline
post #11 of 32 (permalink) Old 08-02-2008, 04:41 AM
You are probably right, but sometimes "it just make you feel better"
post #12 of 32 (permalink) Old 08-05-2008, 12:52 AM
Guest
Amir, if you've not purchased any guards yet, check this out...
The "CalSci Fairing" post in the "Cosmetic Modifications" section has some Acerbis guards that look the mutt's nuts!!! I will be ordering mine very soon here. They are either Acerbis Multiconcept "E" or "T" hand guards. Here are the links for the Acerbis site.
http://www.acerbis.com/p106_handguard/129107.html
http://www.acerbis.com/p106_handguard/129108.html
Hope this helps.
Fukken cheers,
Erik!!!
*EDIT* They look to go on with little to no mods, with the swivel mount.
Motodevil is offline
post #13 of 32 (permalink) Old 08-05-2008, 11:56 PM
DBD34's Avatar
I have a set of Barkbusters from Twistedthrottle, they just bolted on, no modifications. Photos attached, great quality but expensive.
DBD34 is offline
post #14 of 32 (permalink) Old 08-06-2008, 10:04 AM
I installed the Acerbis Rally Pro II handguards this week, went on easy and the only modification needed was cutting the plastic wiring retainers which were replaced with more sturdy zip ties.
I also did an unplanned destruction test on the bar end weights. Got some longer bolts to go through both the weights and handguard and tightened them down, but not excessively - or so I thought. I pushed the centers out of the bar end weights and they fell off So, like Gustavo, I'll be running mine without the weights
Stillupright is offline
post #15 of 32 (permalink) Old 08-06-2008, 11:14 AM
This thread has given me a quick question about handguards so I'll ask here.
Do they all have a metal backbone, or are some of them just plastic? I'm just curious.
EDIT: NM, Google had the answer for me.
hugerider is offline
post #16 of 32 (permalink) Old 08-10-2008, 11:56 AM
DBD34,
Could you provide the part numbers? It looks like BB.BHG6 for the guards. Is the mounting kit BB.BSC.STD?
Thanks,
stargazer
stargazer is offline
post #17 of 32 (permalink) Old 08-10-2008, 02:49 PM
DBD34's Avatar
Stargazer, those are the correct part numbers, but you have to add BB.B56 Versys bar ends, another $45.00. I should also mention that there was no conflict with the stock windscreen but we had to shim my Givi to make it work..
Gary
DBD34 is offline
post #18 of 32 (permalink) Old 08-10-2008, 05:05 PM
Thanks very much and for the info on clearing the windscreen. $45 for the bar ends seems a little high but I like the way they fit and the other features so this is what I am going to buy.
post #19 of 32 (permalink) Old 08-10-2008, 10:05 PM
Enemy Zero's Avatar
DBD34, do you have any issues with the Handguards with the Givi screen installed? I've been looking to do some hand guards but have been worried about clearance with the Givi screen.
Enemy Zero is offline
post #20 of 32 (permalink) Old 08-10-2008, 11:17 PM
DBD34's Avatar
Enemy Zero, Yep, there is a conflict between the Barkbusters and the Givi windscreen, the Givi is flexible enough so they will work together. To be safe
by buddy installed longer bolts and shims between the Givi and the windscreen mounts. The Barkbusters barely touch the Givi, I should be OK.
Gary
DBD34 is offline
Similar Threads
handguards? johnnail Modifications - Cosmetic - V-650 20 12-11-2008 11:00 PM
Acerbis Flag Handguards Arnott_exZX7 Modifications - Cosmetic - V-650 31 11-05-2008 08:00 PM
Handguards and Winscreens-A problem dallasdon Modifications - Cosmetic - V-650 28 10-29-2008 09:02 AM
'08 KLR Handguards on a Versys? Too Tall Modifications - Cosmetic - V-650 8 09-08-2008 07:26 AM
Help! Handguards! amir_zwara Modifications - Cosmetic - V-650 1 08-30-2008 09:13 PM
