Faring Buzz- GONE - Kawasaki Versys Forum
post #1 of 3 (permalink) Old 06-11-2010, 07:00 PM Thread Starter
blipco's Avatar
Faring Buzz- GONE
I put some dense 1/8" foam under the front tab and that helped a lot but to quiet things down altogether, as my twenty minute slow ride at 4500 rpm without earplugs just confirmed, I used a very soft closed cell foam rubber on top of the gauges. I got the foam rubber off a construction site. It is the type used by pipe coverers to insulate chiller units. It comes in sheet form and is black in color. I cut a piece 7 1/2" long and 1 1/4" wide. The rubber measures 17/32" thick in it's relaxed state. I laid it on top of the speedo housing under the black plastic shroud that finishes off the dash board. It is a snug fit and is held squeezed in place. It absorbs the vibes I guess. That's it. I'd take a picture of it but I doubt you'd see anything. The closest Home Depot would have is the black soft rubber tubes for insulating pipes. The more expensive stuff not the stiff brown one. It works!
NEVER MIND, this has been covered a million times.
blipco is offline
post #2 of 3 (permalink) Old 06-11-2010, 07:25 PM
buffamazon's Avatar
Send a message via Yahoo to buffamazon
Hey don't do the nevermind thing...lol. Lots of fixes from lots of folks, as long as they work they deserve being posted. Hell, even those that don't work. I just hit 300 miles and the buzzing just began on my V, so that will be my fix for the weekend!
Thanks!
09 Versys In Go-Fast Green
Acerbis Pro Pack Handguards
Ogio Tailbag
Ogio Saddlebags
Vortex 44T Sprocket
Wolo Bad Boy Air horn
Trackside 12 volt power adaptor
buffamazon is offline
post #3 of 3 (permalink) Old 06-11-2010, 08:46 PM Thread Starter
blipco's Avatar
Thanks!
Very good Buff, maybe you can add a few of your own.
blipco is offline
