Auxiliary Shelf - Kawasaki Versys Forum
post #1 of 7 (permalink) Old 08-18-2015, 03:07 AM Thread Starter
Auxiliary Shelf
Built a aux shelf out of abs plastic.
Mounts with a couple bolts to the top of my Madstad.
Good for GoPro or radar detector...
flyer88 is offline
post #2 of 7 (permalink) Old 08-18-2015, 06:52 AM
I like the flexibility of that mount. How do you plan to attach the GoPro or radar detector?
Are you going to drill mounting holes or something like Velcro?
Mitch
Slow-Steady is offline
post #3 of 7 (permalink) Old 08-18-2015, 09:04 AM Thread Starter
Probably Velco
But it could be easily drilled out for a more permanent mount and maybe better theft protection.
If I screw it up or just want to change it out.....it's very easy to build another.
ABS is nice to work with and waterproof.
flyer88 is offline
post #4 of 7 (permalink) Old 08-18-2015, 10:12 AM
Originally Posted by flyer88 View Post
Probably Velco
I used a couple samples of a very similar looking material (mine was from bathroom stall partitions) to make the attachment blocks for the top box.
Very easy to work with an strong enough for a lot of applications. I tapped mine and just threaded right into it. I did epoxy too, but I'm sure the threads would have held just fine.
Mitch
post #5 of 7 (permalink) Old 08-18-2015, 09:42 PM Thread Starter
I built it mainly for highway use just in case I want to mount my gGoPro and it seems to work pretty well
nice thing is it's not permanent and I'll probably take it off most of the time in the city
flyer88 is offline
post #6 of 7 (permalink) Old 08-20-2015, 08:08 AM
Nice work but I hope the GoPro won't vibrate too much. Good for the GPS for sure
I am but a Traveller in Steel and a Shooter of Birds and MotoGP trackside.
Last life -
GSXR 750 SRAD
Duc 996sps
OrientXpress2 is offline
post #7 of 7 (permalink) Old 08-20-2015, 07:46 PM Thread Starter
I did a little test run with the GoPro the other night.
It seems to stay fairly steady except for when you're idling at a light.
flyer88 is offline
