swap: KLR kickstand - Kawasaki Versys Forum
post #1 of 11 (permalink) Old 07-13-2015, 12:35 PM Thread Starter
kohburn's Avatar
swap: KLR kickstand
while functional, it doesn't make the bike perform better so here it is under cosmetic.
this is my favorite mod of the week. swapped on a 2008 klr kickstand with new spring. the foot is about 3x the surface area of the versys stand, a bit beefier, and sits about 2-3 inches farther out than the versys stand. angle of the lean is unchanged but it is so much more sure-footed even on my sandy yard.
the stock stand would sink in instantly the klr stand not at all.
I'll add a pic later
kohburn is offline
post #2 of 11 (permalink) Old 07-14-2015, 07:48 PM Thread Starter
kohburn's Avatar
Could be more clear but I keep getting home around dusk.
kohburn is offline
post #3 of 11 (permalink) Old 07-14-2015, 10:33 PM
kevrider's Avatar
so it's not longer than a versys side stand?
Seal/CRAZY/misquoted
kevrider is offline
post #4 of 11 (permalink) Old 07-14-2015, 11:22 PM
post #5 of 11 (permalink) Old 07-15-2015, 05:48 PM
Are you trying to sell (or swap) the KLR stand for a V stand...?
How many $ for the KLR stand?
post #6 of 11 (permalink) Old 07-16-2015, 01:31 PM Thread Starter
kohburn's Avatar
no, no... I just swapped a KLR stand on in place of the stock stand. its a nice improvement. I would happily part with the stock stand.
used price was about 25$
kohburn is offline
post #7 of 11 (permalink) Old 07-16-2015, 01:32 PM Thread Starter
kohburn's Avatar
its a hair longer, but it places the foot a little farther out to the side.
end result is that the bike sits the same as stock.
kohburn is offline
post #8 of 11 (permalink) Old 07-16-2015, 07:58 PM
how is it to kick down? I notice it doesn't have the little kick pin on it. could you get a picture with it in the up position?
Thunder Blue 2013 Versys
ThunderBlue is offline
post #9 of 11 (permalink) Old 07-17-2015, 06:43 AM Thread Starter
kohburn's Avatar
yeah I can do that later.
the stock one is a straight leg with a pin sticking out. this leg jogs to the side just as far as the pin stuck out. so you actually kick down the whole leg rather than a pin. no problems.
kohburn is offline
post #10 of 11 (permalink) Old 07-19-2015, 10:12 PM
andrewhtf's Avatar
too bad we dont have a breaker yard around in my country, and a used KLR stand is out of question unless i get it from ebay.
and if i were to use a klr stand, i'd weld a kick stand pin in. just habit.
Current : Maroon 2011.
Up next :
andrewhtf is offline
post #11 of 11 (permalink) Old 07-24-2015, 06:31 AM Thread Starter
kohburn's Avatar
good thing I had that new kick stand. the stock one would have sunk into the pavement with this heat and tipped the bike over. this stand the far edge hits first so it sunk in just enough to put the foot flat then it stopped. I already know that parking on coastal sandy soil is a success vs the old stand would sink in instantly and I'd have to hold the bike up while looking for something to put under the foot.
kohburn is offline
