Removable back rest? - Kawasaki Versys Forum
post #1 of 12 (permalink) Old 05-20-2010, 10:42 PM Thread Starter
RedNomad's Avatar
Hello Versys Owners,
I was looking at backrest for the passenger and I see you can buy very expensive permanent ones, or some folks have made their own. I was wondering if anyone has seen something that could be clamped or bolted onto the grab handles as a temporary backrest? Most of the time I would prefer to ride without one but it could be handy if you have a passenger that is a little timid.
Thanks,
RedNomad
RedNomad is offline
post #2 of 12 (permalink) Old 05-20-2010, 11:58 PM
amir_zwara's Avatar
back rest w/ functionality = topbox
amir_zwara is offline
post #3 of 12 (permalink) Old 05-21-2010, 05:45 AM
I have a question to add to this. I bought the backrest to go with my new topbox, but I actually need to drill the holes and fit it. Not a problem in itself, as it comes with a diagram you can fit to the box to get the holes exactly right.
What does worry me is what happens when it rains?????????
Has anyone else had to do this?
spainy is offline
post #4 of 12 (permalink) Old 05-21-2010, 05:22 PM
Remy's Avatar
Spainy, you could wrap the bolts/holes with that shower-nozzle tape that stops leaks.
Cheap and effective. Shouldn't even be visible either.
Remy is offline
post #5 of 12 (permalink) Old 05-21-2010, 07:44 PM
I got poured on coming home from work the other day and I didn't get any water in my top box. I have a Givi E370 with the back pad. The pad mounts through the top box with two bolts/screws, but the rubber washers that go on the bolts/screws seal things up nicely. I think it would be more likely water would get in around the edge of the box, but my laptop was nice and dry when I got home. Unfortunately, I wasn't expecting rain and left my rain gear at home that day, so I was soaked.
GreenMeenie is offline
post #6 of 12 (permalink) Old 05-25-2010, 06:32 AM
Thanks for the tips guys. Will check to see if rubber washers are included, didnīt think of that.
spainy is offline
post #7 of 12 (permalink) Old 05-25-2010, 08:13 AM
sharrison56's Avatar
I have the backrest on my E52 and have never had trouble with water getting in and I have been in some real downpours with it.
Steve
Now I have four!
sharrison56 is offline
post #8 of 12 (permalink) Old 05-25-2010, 08:20 AM
Did you have to drill it on also?
spainy is offline
post #9 of 12 (permalink) Old 05-25-2010, 08:29 AM
Yes. I also have the top rack on the case and it had to be drilled to. I have had no leaks.
Steve
Now I have four!
post #10 of 12 (permalink) Old 05-27-2010, 09:40 AM
Aleeoop's Avatar
The stock grab rails are fairly flexible and soft. It would likely damage them to clamp something to them and if you did, the backrest would probably flex a lot which wouldn't be reassuring to the passenger. The top box is probably the best way to go. I have the SW Motech top rack from Twisted Throttle. It replaces the grab rails too and is very solid. Everything they make that I have tried is excellent and a good value. I think it was around $165 (American).
Aleeoop is offline
post #11 of 12 (permalink) Old 05-27-2010, 09:42 AM
Aleeoop's Avatar
The Corbin seat has a fitting receiver for their own removable backrest and you can keep the stock grab rails if you like.
Aleeoop is offline
post #12 of 12 (permalink) Old 05-28-2010, 01:53 AM
shabadoo's Avatar
+1 for the corbin option, if you're ok with throwing money at the problem to make it go away. i have had them on two bikes now, by far most pro backrest solution, especially if you don't want to roll a top case. the corbin saddle does look killer on the v.
shabadoo is offline
