Brackets/clamps for front forks - Kawasaki Versys Forum
post #1 of 5 (permalink) Old 05-05-2015, 04:56 PM Thread Starter
Am considering putting my aux. lights down on the forks so the turn signals are still visible. Has anyone ever tried using any of these products made for mounting light fixtures on the top rails for off road buggies. They come in 1.5", 2" and 3" units, and appear cheap compared to most billeted stuff we run across for our bikes.
rayj
2009 Versys (Mine's Green)
rayj is offline
post #2 of 5 (permalink) Old 05-05-2015, 05:23 PM
Time's Avatar
Sorry, Superbrightleds.com beat you to it. And they have a larger choice as far as clamp size. Likely not as cheap as others but they sell good stuff.
https://www.superbrightleds.com/more...ight-bar/1746/
Or was that look THEN leap?
2012 650 Versys
Time is offline
post #3 of 5 (permalink) Old 05-05-2015, 07:52 PM
I am not sure what lights you have, but hopefully this application may be useful for you. http://www.twistedthrottle.com/denal...fset-mount-kit
I currently have SW-Motech's auxiliary mount installed and my turning signals are not hidden. http://www.twistedthrottle.com/sw-mo...i-versys-07-09
File Type: jpg 11139435_10152878984055784_1852947931002751436_n.jpg (40.4 KB, 45 views)
TaiDinh is offline
post #4 of 5 (permalink) Old 05-06-2015, 06:05 AM
andrewhtf's Avatar
U bolts. 4 nuts. Rubber strip cut out from tyre tubes. A piece of metal strip, with 3 holes drilled. Cheap. Works.
Current : Maroon 2011.
Up next :
andrewhtf is offline
post #5 of 5 (permalink) Old 05-06-2015, 10:46 AM
BaileyMan's Avatar
I used T-bolt clamps with good success when I mounted auxiliary lights to my forks.
2011 Imperial Red
A little bit of road rash
BaileyMan is offline
