How do I fit Triumph Street Triple Mirrors?? - Kawasaki Versys Forum
post #1 of 5 (permalink) Old 05-03-2010, 11:23 PM Thread Starter
I'm getting "Street Triple" mirrors to go on my versys. I know that the versys is 10mm threads and I don't remember what the Triumph is, same as KTM I think.
As I understand it I can use a adapter from KTM or whoever that will just raise my mirrors 1/2" or so vertically. I also see on ebay mirrors extenders that are adapters for putting 10mm mirrors on the Street triple. I assume that somewhere I should be able to find adapter extenders to put the triumph mirrors on the Versys.
Or maybe I can buy regular 10mm mirror extenders and then buy a stainless steel hex-head bolt in whatever thread pitch the triumph is at the local hardware store?? Would that work??
Any ideas?? I'm not even sure I'll need extenders yet, I think the Triumph mirrors are a bit wider but I'd really like to be able to see behind me.
Thanks for the help!!
Goblin is offline
post #2 of 5 (permalink) Old 05-04-2010, 06:12 PM
Why don't you either find out what size the ST3 mirrors are, or wait until you get them.
If it's a 10mm, then you need nothing else. If it's a 8mm, then buy the KTM mirror adapters made for a 2001 or 2002 Duke.
I have a set of 2001 KTM Duke mirrors on my Versys and used the adapters. Works perfectly.
ChainLash is offline
post #3 of 5 (permalink) Old 05-04-2010, 10:48 PM
A2RON's Avatar
I fitted the Street Triple mirrors back in December last year (3,000 miles so far).
The Triumph P/N's:
Left Hand P/N T2060019
Right Hand P/N T2060018
each mirror was US$ 68.57 and they came with the rubber boot.
http://www.kawasakiversys.com/forums...ead.php?t=5886
They are the same threads as the Versys, I mounted them to my eBay extenders.
A2ron
Charleston, SC
A2RON is offline
post #4 of 5 (permalink) Old 05-09-2010, 01:25 AM
antman325's Avatar
Not only would I like to fit those mirrors, I also dream of fitting a Street Triple motor too. Looks like it would be a close fit...would this be in any realm of possibility?
"When It Rains, Get Wet"
antman325 is offline
post #5 of 5 (permalink) Old 05-13-2010, 07:17 PM Thread Starter
Well I finally got the mirrors and you guys were right, they just bolted right on. They look great and extend a good 2-2 1/2" beyond what the stock ones did.
I didn't have time for a ride but with them being lower and wider I'm hoping they will be okay without extenders.
...about the motor swap... ...they'll sell you a street triple you know? Seems it would be easier to buy one, change handle bars, and add a windscreen than it would to do an engine swap on the Versys. But maybe I'm missing the point. I do love the sound of that triple.
Goblin is offline
