Swingarm spools - 15 650 - Kawasaki Versys Forum
post #1 of 16 (permalink) Old 02-08-2015, 06:39 PM Thread Starter
Kidder's Avatar
Can an owner of the new 2015 650 confirm the swingarm spool mounts are 10mm x 1.25 thread? I assume they are.
2015 Versys 1000 LT
Kidder is offline
post #2 of 16 (permalink) Old 02-09-2015, 01:02 AM
andrewhtf's Avatar
my guess - they should be the same as the 1st & 2nd gens.
Current : Maroon 2011.
Up next :
andrewhtf is offline
post #3 of 16 (permalink) Old 02-11-2015, 04:03 PM
The set I just installed is 8mm. Of course I only learned this after buying a 10mm set first.
robb is offline
post #4 of 16 (permalink) Old 05-09-2015, 10:44 PM
BKP
BKP's Avatar
Rear frame sub-assembly/swingarm was changed on the 2015 (carries more weight, etc.). They changed the spool mounts from 10mm to 8mm...
BKP is offline
post #5 of 16 (permalink) Old 05-10-2015, 03:54 AM
Doesn't really make sense does it? More weight=smaller bolts....Granted the spools are not made to carry the bike or anything BUT you DO pick it up on them with a paddock stand.
post #6 of 16 (permalink) Old 05-10-2015, 09:00 AM
BKP
BKP's Avatar
Well... I don't know their logic in this. The new sub-frame adds additional capacity from above. Probably did the 10mm to 8mm switch independently of the decision behind reinforcing the sub-frame. I'm sure there was a reason. Mfgrs don't like to change specs without cause...
BKP is offline
post #7 of 16 (permalink) Old 05-10-2015, 09:14 PM
8mm!!!
8mm... Ask me how I know....
Apollo12227 is offline
post #8 of 16 (permalink) Old 05-14-2015, 10:01 AM
Timberdog's Avatar
Yep, 8mm just put some on.
Timberdog is offline
post #9 of 16 (permalink) Old 04-20-2016, 03:09 PM
chid's Avatar
can somebody recommend some nice green ones? (with a SS bolt)
the length of the bolt is important?
Versys 2015 Green
chid is offline
post #10 of 16 (permalink) Old 04-20-2016, 04:13 PM
These look like they should work:
8mm CNC Swingarm Spools Green for Honda CBR 600RR 900RR 929RR 954RR 1000RR F4i | eBay
These are the ones I am using, but they are not available in green:
http://www.amazon.com/Vortex-SP526K-...Swingarm+Spool
Green Streak is offline
post #11 of 16 (permalink) Old 04-20-2016, 04:27 PM
These are standard sized for all bikes and very cheap on Ebay.
post #12 of 16 (permalink) Old 04-20-2016, 09:08 PM
cuckoo's Avatar
2015 = 8mm.... Not standard... but get em if ya want to!
cuckoo is offline
post #13 of 16 (permalink) Old 04-21-2016, 01:10 AM
Twisted throttle sells the SW-Motech kit for the Versys, it comes with 10M x 1.25 x 30 bolts.
My 2010 Versys 650 takes 10mm spools and has the exact same swing arm as a 2015 Versys. I would suggest double checking with your dealer parts guy before purchasing if you are in doubt.
http://www.kawasakiversys.com/forums...l-sliders.html
post #14 of 16 (permalink) Old 04-21-2016, 08:38 AM
The size has changed in gen3 (2015) to 8mm, don't know why but it did.
2015 Versys 650
_Big_Mac_ is offline
post #15 of 16 (permalink) Old 04-21-2016, 04:53 PM
The Gen 3 ('15 and '16 Vs) ARE 8mm, which is more than big enough!
I used two 8mm bolts w/ 'jam' nuts as 'spools' till a got a set on Ebay. You can see the right-side bolt in this pic....
post #16 of 16 (permalink) Old 04-21-2016, 05:23 PM
Smiley's Avatar
I had a major problem with my first set: see link below. I replaced them with steel and they have been very rugged.
http://www.kawasakiversys.com/forums...e-bobbins.html
Smiley is offline
