2015 V1K Farkel begins - Kawasaki Versys Forum
post #1 of 17 (permalink) Old 01-20-2015, 06:16 AM Thread Starter
IF1960's Avatar
Well it's been 4 Whole Days of ownership.. I had to do something.
Removed the reflectors from the forks/front guard, they were only finger tight
Ordered a couple of RAM mounts Saturday and they arrived this morning. Mounted the old GPS and Drift Cam.
Oxford Grips have been ordered as has a power socket. I'll wait till they are both here before pulling plastics off and finding connections for the electrics,
Ian
Growing Older is Inevitable, Growing Up is Optional.
IF1960 is offline
post #2 of 17 (permalink) Old 01-20-2015, 07:27 AM
Nice!
2013 Kawasaki Versys- Blue/Black
2014 Honda Grom- Red/Black
2014 Yamaha Grizzly 350 Blue/Black
2012 Kawasaki KLX250s Red/Black
Obijack is offline
post #3 of 17 (permalink) Old 01-20-2015, 08:54 AM
saddlebag's Avatar
Well done. For the record, Kaw does make a bracket that fits a GPS directly above the speedo. Not sure what all it fits. As I have a Zumo 550, I'll probably go this route.
http://www.moto-passion.co.uk/kawasa...s-bracket.html
saddlebag is offline
post #4 of 17 (permalink) Old 01-20-2015, 10:30 AM
post #5 of 17 (permalink) Old 01-20-2015, 08:42 PM Thread Starter
IF1960's Avatar
Screen support on the 2015 V1K is a bit different to the 13.. be worth checking before spending your coin Just in case.
Ian
IF1960 is offline
post #6 of 17 (permalink) Old 01-20-2015, 09:56 PM
Nice! Reflector removal was one of the first things I did as well. Be careful or your bike will look like mine in less than 6 months
post #7 of 17 (permalink) Old 01-21-2015, 12:46 AM
saddlebag's Avatar
Yeah, I noticed it was listed as fitting a '14, but I read about it on the '15s somewhere. You can see one fitted in this pic:
post #8 of 17 (permalink) Old 01-21-2015, 12:50 AM
saddlebag's Avatar
I was looking at the reflector on the 650 and it seemed to be fitted to the end of a funny looking bolt/stalk. Appears to me like you'd need to get a proper bolt for the fender if you wanted to remove the reflector and the stalk, no?
post #9 of 17 (permalink) Old 01-21-2015, 01:06 AM
Exactly right. The reflector and stalk removed and If I remember right, it was a standard 10 mm or similar. Pretty easy.
post #10 of 17 (permalink) Old 01-21-2015, 10:58 PM
I like that color!
I think Oxford grips were the 1st farkle on my 2011. After a power outlet for heated gear--but that hardly qualifies as a farkle.
davidg is offline
post #11 of 17 (permalink) Old 01-22-2015, 08:19 AM
IanThomas's Avatar
I'm so jealous of the 1000's, but not of the payments.
- Ian Thomas
2013 Versys
IanThomas is offline
post #12 of 17 (permalink) Old 01-24-2015, 03:48 AM Thread Starter
IF1960's Avatar
Oxford Grips
Well the grips turned up and I had a couple of hours spare ... So.. on they go
Pretty simple. Took the old ones off with a small long screwdriver and WD40.. slid right off.
Pulled the side cover and found the stock Heated grip connection.. Different pins and housings but with a bit of Jerry rigging i was able to get it sorted without getting the soldering iron out, Win.
I purchased the Adventure" Oxfords, fitted the left bar first. Forkin tight and I had to trim the outer ring off the grip to fit. expected that, all good.
Trimmed the Throttle to the same length. It went on much easier but was too long. Trimmed in situ which was not ideal.
Used the supplied controller bracket and spacers making a securing bracket from a U bolt, painted black as was the Oxford bracket.
All works as it should, powers off with the ignition and runs the OEM fused circuit.
Ian
IF1960 is offline
post #13 of 17 (permalink) Old 01-24-2015, 09:15 AM
goat12's Avatar
Nice looking 1000! I have the same Oxfords. Absolute must to ride all year round here in the Northeast US.
goat12 is offline
post #14 of 17 (permalink) Old 01-24-2015, 04:06 PM
saddlebag's Avatar
The last time I tried to take the bar ends of a Kaw was a ZRX1200. They red Loctited them at the factory. I had to go buy a manual impact wrench with a Philips head to get the damn things off.
post #15 of 17 (permalink) Old 01-25-2015, 09:23 AM
Smiley's Avatar
I replaced the chrome bolts with black, like the look better.
See in this photo.
Smiley is offline
post #16 of 17 (permalink) Old 01-25-2015, 11:35 AM
See in this photo....
Smiley - IF you require reflective something up front by law, try adding a bit of yellow reflective tape to the lowest portion of your forks (which is what I've done).
post #17 of 17 (permalink) Old 01-25-2015, 12:37 PM
Smiley's Avatar
I suppose I might do that IF I'm forced to. Reflectors on the front of bikes are useless for anything except parking in a dark place. Reflective material on the back is a totally different matter. I use silver reflective tape on my helmet.
Smiley is offline
