Paint matching website found. - Kawasaki Versys Forum
post #1 of 3 (permalink) Old 03-12-2010, 04:42 PM Thread Starter
http://www.colorrite.com/index.cfm?killnav=1
Follow the "paint wizard" and you can find your V's color match on this site. Order a touch up pen or a spray can, or a regular paint can of the stuff. I'm on the fence about ordering it only because two cans, the base layer and top layer, will run 67 bucks before shipping. Either way, i thought it was a cool find.
mcampana is offline
post #2 of 3 (permalink) Old 03-12-2010, 05:20 PM
Been checking that site out for a couple of weeks now when you go to check out they also suggest primer and a clear coat if you go that route you're at about 120.00 plus shipping. My debate on the matter is over putting the hugger and fenda extender on non-painted tomorrow
post #3 of 3 (permalink) Old 03-13-2010, 07:55 AM
MagpieTear's Avatar
Color-rites paints are spot on, if you follow the directions for the base/color/clear. However, unless you're dealing with a factory pearl, quite often you can be better served by hitting a local autobody supply shop for anything larger than a touchup pens worth of paint. Color-rite gets stupid expensive quickly.
MagpieTear is offline
