front fender extender instal question - Kawasaki Versys Forum
post #1 of 34 (permalink) Old 03-10-2010, 03:29 PM Thread Starter
How many of you used the supplied screws to instal the fender extender? I was almost thinking you just used the adhesive tape that comes on the extender.
mcampana is offline
post #2 of 34 (permalink) Old 03-10-2010, 04:08 PM
LoneRanger's Avatar
I did. I also used some plastic weld I had. I ride in cold and hot temps rain or shine and I didn't want the Fender Extender flying off. Don't really notice the screws. Protects the Radiator as Advertised!
LoneRanger is offline
post #3 of 34 (permalink) Old 03-10-2010, 04:35 PM
I fitted mine with supplied glue strips and added Bison glue for good measure.
Few hundred KMs later, I think I'm going to put some screws with nuts after all.
It's really not that noticeable with 3 screws at the bottom.
Ivan V is offline
post #4 of 34 (permalink) Old 03-10-2010, 06:10 PM
I sanded the under side of the fender and used ABS cement and clamps ,works great . no problems . ride safe
bultaco is offline
post #5 of 34 (permalink) Old 03-10-2010, 06:56 PM
morphydt's Avatar
You could also use some 5 minute epoxy or, if you are careful, PVC pipe glue, you know the purple stuff probably a little messy
Dan
life happens, ride often
morphydt is offline
post #6 of 34 (permalink) Old 03-10-2010, 07:10 PM Thread Starter
Claps?
mcampana is offline
post #7 of 34 (permalink) Old 03-10-2010, 08:03 PM
I used both the tape that is already attached and the screws. Installed screws in place that matched the picture on the pamphlet that came with it for thier other products. 3600 miles still tight,radiator clean.
2009 Lime green Versys
Hepco & Becker crash bars
Givi side carriers w/ E21's
Fenda Extenda
cut tail fender
black lower panels
Sw-Motech 20mm riser
Randy49 is offline
post #8 of 34 (permalink) Old 03-10-2010, 08:52 PM
I threw away the adhesive tape and used 30-minute epoxy - after cleaning the underside of the fender. I taped it in place until the epoxy hardened. Some good clamps would have helped.
ScottyNeal is offline
post #9 of 34 (permalink) Old 03-10-2010, 09:16 PM
VeeWNC's Avatar
Used epoxy
17,000 miles later, it's still holding up good and that's saying something, considering how often it got snagged behind the Happy Trails bash plate.
Don't you think that it's a ^%#$&# shame that Hunter S. Thompson wasn't an adventure rider? Imagine the ride reports...!
VeeWNC is offline
post #10 of 34 (permalink) Old 03-10-2010, 10:35 PM
clamped them together till the cement setup. my bad sorry
bultaco is offline
post #11 of 34 (permalink) Old 03-11-2010, 01:51 AM
After bonding it in place with the tape, I permanently secured the Fenda Extenda using a hot glue gun and heavy duty glue sticks, melting and blending both parts together. I also 'welded' it at the screw holes, while feeling for excess heat on the painted side to prevent damaging or warping it.
post #12 of 34 (permalink) Old 03-14-2010, 09:25 PM
JimJim's Avatar
I removed the tape, scuffed both surfaces with sandpaper and used marine grade epoxy, no screws.
JimJim is offline
post #13 of 34 (permalink) Old 02-05-2011, 07:23 PM
cmoreride's Avatar
You see I went back and sought out this thread. I today received a new fenda extenda.
This thread gives input regarding the screws vs adhesive vs combo question. Now to do a good job I want to remove my front fender. I would prefer to cut the three brake line holders and replace with new ones. I don't like the idea of pulling the current ones out. If I did their future holding ability would be degraded. I assume many would just reuse the old ones. I can't find the part in the OEM drawings at Bike Bandit. If I can get news ones for 10$+- I'll use new ones. Anyone found them? Can you point me in the right direction? Could there be a "trick" to removing the current ones without damaging the barbs on the inserts?
cmoreride is offline
post #14 of 34 (permalink) Old 02-05-2011, 10:14 PM
kimel's Avatar
I think you want this page: http://www.cheapcycleparts.com/model...semblies/41049
Part # 92171 or maybe Part # 92170 or both.
2009 Kawasaki Versys
kimel is offline
post #15 of 34 (permalink) Old 02-05-2011, 11:06 PM
Ziggy's Avatar
No need to remove the fender or use the screws. I have installed several fender extenders without losing one or having one loosen using the below method.
Purchase a roll of Scotch brand (3M product) permanent outdoor mounting tape and install on the extender in the areas where there is no tape from the factory.
Clean the mounting surface of the fender and install.
The extender can be removed if you ever choose to, but is very secure.
Ziggy is offline
post #16 of 34 (permalink) Old 02-05-2011, 11:45 PM
cmoreride's Avatar
That be it.
Thanks for you time and effort.
BG
post #17 of 34 (permalink) Old 02-05-2011, 11:50 PM
cmoreride's Avatar
Thank you for your response. Have not decided which method I'll use.
Seems about a finger's worth of clearance from fender to tire to work with, for cleaning.
P.S.
Just looked up that product that certainly appears to be able to do the job.
http://www.amazon.com/Scotch-Permanent-Outdoor-Mounting-4011-LONG/dp/B000BL5INM
post #18 of 34 (permalink) Old 02-06-2011, 08:52 AM
P.S.
I tried several different tapes. Poor results with all the wet riding i do. Didn't want to use the screws. Took off fender scuffed up Fender Extenda and Fenders contact area used Gorilla Glue Epoxy Kit and clamped overnight. No issues at all anymore. Much cleaner look than using the screws and its not going anywhere.
post #19 of 34 (permalink) Old 02-06-2011, 11:21 AM
I used 2 of the screws supplied. Would have added a 3rd but couldnt fit the drill in place w/o removing the fender. Noticed they extend very close to the tire so backed out and added a couple washers on each. Seems to work fine.
T
puttman is offline
post #20 of 34 (permalink) Old 02-06-2011, 12:25 PM Thread Starter
Im glad this was brought back up. I still haven't installed my extender. These new tips will help, and give me something to do while waiting for the snow to stop!
mcampana is offline
