Ram Mount for a 60csx gps - Kawasaki Versys Forum
post #1 of 7 (permalink) Old 02-15-2010, 03:28 PM Thread Starter
Does anyone have a garmin gpsmap 60csx mounted on their bike? I have been looking at the mounts available for this unit at www.ram-mount.com and there are quite a few available.
I am thinking the RAM-B-149ZU which mounts onto the handlebars is probably the best bet that will work but is also the most likely to be less stable.
http://www.ram-mount.com/CatalogResu...5/Default.aspx
emur is offline
post #2 of 7 (permalink) Old 02-15-2010, 05:55 PM Thread Starter
thanks JD,
I will give that one a go then.
emur is offline
post #3 of 7 (permalink) Old 02-15-2010, 09:32 PM
A2RON's Avatar
I had the Ram handlebar mount for my Nuvi, I found that it seemed to vibrate a bit too much and I didn't l like it moving around. I ended up buying a baseplate and the Motowerk (Speedy) Tom-Tom mount for the windscreen bracket and mounted my Nuvi above my instrument cluster.
Tucked under the windscreen, it is more protected from the elements too.
A2ron
Charleston, SC
A2RON is offline
post #4 of 7 (permalink) Old 02-18-2010, 03:12 PM
scotty_h's Avatar
get in the habit of tying the wrist strap off. if you drop the bike, the gps might go flying. probably won't be damaged, but if not tied off, you could have trouble finding it.
+1 on the wirst strap tie. I hit a turkey (yeah I know, I do live in KY though) and my GPS was the first thing to hit the ground. A few scratches and it was back in place, but a close call for a nice unit.
I found the handlebar mount plastic to loosen after 15K where the gps bracket snaps into the handlebar attachement. So it shakes a bit, but at 16 dollars I could probably get a new one.
jd- BMW Tommy says Hello,
scotty_h is offline
post #5 of 7 (permalink) Old 02-18-2010, 03:24 PM
DBD34's Avatar
I'm using a Ram mount and a 60 csx, I've been on a lot of rough roads lately, no problem.
Gary
DBD34 is offline
post #6 of 7 (permalink) Old 02-18-2010, 09:41 PM
bscott's Avatar
I've bought a few RAM mounts from GPSCity, not one for the 60CX, but I did buy one for a Vista HCx for my KLR, and one for my Nuvi 550 for the V.
Here is GPSCity's Canadian site if you're not familiar with them.
http://www.gpscity.ca/rammounts
2008 Versys, SOLD!
2002 BMW R1150RT Lovin it!!!
bscott is offline
post #7 of 7 (permalink) Old 06-22-2010, 09:37 AM
Hardware's Avatar
... if you drop the bike, the gps might go flying. probably won't be damaged, but if not tied off, you could have trouble finding it.
Which in turn could mean that you’ll have a hard time telling the paramedics where to find you
~~ Live Like You're Dying ~~
Hardware is offline
