Versys Beak + + - Kawasaki Versys Forum
post #1 of 15 (permalink) Old 11-29-2014, 07:23 PM Thread Starter
BKKPhil's Avatar
Versys Beak + +
I know it's not for some but I like it.
Decided to put a beak on modified from a Honda pcx, I think it looks better.
Recently installed SW-Motech Cobra with turn signal as the Barkbusters stook a hammering recently. Installed SW-Motech rear rack and foot pegs and just changed the Scorpions to MT60s. Kriega accessories too.
Now there's a spanner in the works. Both the Triumph and BMW ranged has dropped in price in Thailand nearly 50 percent! They were typically twice the price of the EU market.
BKKPhil is offline
post #2 of 15 (permalink) Old 11-29-2014, 10:47 PM
Are those the Mitas tires you are running? How do you like them?
post #3 of 15 (permalink) Old 12-10-2014, 06:59 AM Thread Starter
BKKPhil's Avatar
Sorry, been away for a while.
They are Pirelli MT60s Corsa, and compared to the previous Scorpions I had they are fantastic. On tarmac they seem great too which is probably down to the soft compound. Just done an off road they inspire confidence on some very steep gravel and rubble sections. Never felt like they would let go.
BKKPhil is offline
post #4 of 15 (permalink) Old 12-10-2014, 07:06 AM
Thaylin's Avatar
Nice looking bike. Can you tell us what windshield and lip you are running and maybe a quick thought on how you like it over the stock one?
Thank You
Thaylin is offline
post #5 of 15 (permalink) Old 12-18-2014, 09:10 PM Thread Starter
BKKPhil's Avatar
Thank You
Sorry, been away again
I use an MRA xcm and at first I was really disappointed as it is quite expensive here. However, when I tried to adjust it the thing fell apart and the well-nuts dropped out. Basically, the garage did a piss-poor job installing it. After I reinstalled it myself, it is great. Wind noise is comparable to the standard, but the buffeting pressure on the body has severely dropped. I like to look as I'm not into the tall Givi versions but my friend really likes his.
Speed wise. With the standard I could barely hit 110kph before the noise and buffeting became irritating. I've done 160kph with this with no feeling of pressure at all.
BKKPhil is offline
post #6 of 15 (permalink) Old 12-19-2014, 01:33 AM
I have that beak / lip on my 2013. It was inexpensive, easy to install and adds a nice touch to the bike without going overboard. Pictures don't do it justice. When you see it on the bike in person it seems like it's designed for it. I just got that rear rack too and I loved my tall Givi. I also like the choice of tires on this bike. Will definitely look at these when the time comes. Thanks for the nice pics!
rydbayb is offline
post #7 of 15 (permalink) Old 12-24-2014, 02:33 PM
kawdog's Avatar
What a great looking bike Phil! I can appreciate what you have done, because it is not easy putting all that stuff together where everything works and flows aesthetically as nice as you have done. I'm envious of your hard work and details. I'll be happy getting half of what you have working well and will refer back to your great pics often for guidance. Congrats!
kawdog is offline
post #8 of 15 (permalink) Old 12-30-2014, 04:05 PM
[quote=BKKPhil;743225]I know it's not for some but I like it.
I've managed to get one of those beaks as well. Would either of you guys be able to post more detailed photos of how you've fitted it, as i'm not sure of how to do the front part under the headlight.
Cheers.
ghost_ is offline
post #9 of 15 (permalink) Old 12-30-2014, 09:52 PM
Picks won't show mine. Attached with plastic ties to the headlight cover, one on each side. Marked then drilled holes on each side (lower side) of the headlight cover and to my liking on the beak (4 total, 2 per side). Looped ties through on each side, tightened lightly to alighn straight then tightened down and cut ties. Attached rear beak flanges to main cowling with one tap screw on each side. Ties in the front allow the beak to easily attach and pivot. Tap screws lock everything down nicely. If done right, ties and screws are invisible. Have had no issues with this method and is easy to remove which I have had to do many times. If you take your time and use small spring clamps to hold everything in place as you mark your holes you will have a clean install that you will be happy with. Again there are several other ways to do this depending on how you want the beak to line-up and attach.
rydbayb is offline
post #10 of 15 (permalink) Old 12-31-2014, 01:00 AM Thread Starter
BKKPhil's Avatar
[quote=ghost_;760657]
I've managed to get one of those beaks as well. Would either of you guys be able to post more detailed photos of how you've fitted it, as i'm not sure of how to do the front part under the headlighIt.
Cheers.
I will post some pics or a vid clip tomorrow if I get the chance. Bike is in office at moment.
BKKPhil is offline
post #11 of 15 (permalink) Old 12-31-2014, 02:49 AM
I've got one of these Honda pcx beaks already pre formed to fit my 2011 that I never got around to installing. If anyone is interested in it shoot me a PM.
post #12 of 15 (permalink) Old 12-31-2014, 02:51 AM
Purificator's Avatar
Will do can't leave something pending in your garage right? :-D
Purificator is offline
post #13 of 15 (permalink) Old 01-01-2015, 07:29 AM Thread Starter
BKKPhil's Avatar
BKKPhil is offline
post #14 of 15 (permalink) Old 01-02-2015, 05:08 AM
Here's a pic.
rydbayb is offline
post #15 of 15 (permalink) Old 01-02-2015, 01:21 PM
Thumbs up
Thanks very much BKKPhil & Rydbayb for the image and bid, pretty much confirmed how I was thinking of mounting it.
ghost_ is offline
