plastics quick releases - Kawasaki Versys Forum
post #1 of 15 (permalink) Old 09-09-2014, 12:53 PM Thread Starter
i was just wondering if anyone has tried any quick releases for the plastics on the versys (08) to replace the Allen bolts.....seems like it would make like alot easier if you have to lets say get to your coolant tank on the side of the road so you dont have to remove 1000 different sized bolts
post #2 of 15 (permalink) Old 09-09-2014, 01:43 PM
Freerydejunky's Avatar
There are only 5 bolts to remove?
Hooligan
Freerydejunky is offline
post #3 of 15 (permalink) Old 09-09-2014, 02:02 PM Thread Starter
plus the 4 nuts and bolts for the windscreen
post #4 of 15 (permalink) Old 09-09-2014, 04:02 PM
You don't take the windscreen off to get to the coolant
post #5 of 15 (permalink) Old 09-09-2014, 04:10 PM
kohburn's Avatar
I can't get to the front bolt on my 08 with the windscreen in place.
kohburn is offline
post #6 of 15 (permalink) Old 09-09-2014, 06:49 PM Thread Starter
you kinda do inless you have a short cut allen key
post #7 of 15 (permalink) Old 09-09-2014, 08:36 PM
djg
Quick release fasteners like Dzus or camlocs need a special receptacle in place of the threaded nuts that the stock bolts use. It would be a big project to remove the welded in nuts and replace them with quick release receptacles.
djg is offline
post #8 of 15 (permalink) Old 09-09-2014, 08:44 PM
Or this windscreen set-up....
post #9 of 15 (permalink) Old 09-10-2014, 01:41 AM
Sorry mines an 2012 so ignore what I said, didn't know what model yours was
post #10 of 15 (permalink) Old 09-10-2014, 02:11 AM Thread Starter
versys (08)
post #11 of 15 (permalink) Old 09-10-2014, 07:00 AM
jmarleau's Avatar
Wonder if this would work?
jmarleau is offline
post #12 of 15 (permalink) Old 09-10-2014, 08:45 AM
kohburn's Avatar
something like this
along with rivet-nuts in the windscreen backet to eliminate the acorn nuts on the backside.
that should be pretty easy
kohburn is offline
post #13 of 15 (permalink) Old 09-10-2014, 08:25 PM Thread Starter
something like this
both of those look like good ideas
post #14 of 15 (permalink) Old 09-20-2014, 02:32 AM
mikej's Avatar
The thought on both types of quick screws is great. Then I think about the people wandering by the bike, seeing the screw and just deciding to take it or loosen it. I got and adaptor from sears, like in photo, and keep the correct sized hex bit in it for the windscreen. Drop that tool in the trunk and I'm all set.
mikej is offline
post #15 of 15 (permalink) Old 09-20-2014, 11:26 AM Thread Starter
ya i went to HF and got some allon T wrench to add to my tool kit and replaced the windscreen nuts with wing nuts and its made like much nicer
