Painting textured plastic? - Kawasaki Versys Forum
post #1 of 46 (permalink) Old 07-02-2008, 07:49 PM Thread Starter
Question Painting textured plastic?
I'd like to paint the radiator covers on my V. The earlier models had them black, and I think it will look better after I put crash bars on. I wouldn't mind painting the pivot (side) covers too.
The how-to guides assume you're dealing with smooth plastic parts, but these pieces on the Versys are textured.
Any ideas?
lost84001 is offline
post #2 of 46 (permalink) Old 07-02-2008, 09:20 PM
What type of "paint" are you talking about? Rustoleum or automotive paint?
If it's Rusto, I'd say just clean them, scuff, prime and paint a few topcoats.
If it's automotive, I think you'll need to consider flexibility, which is where your rustoleum is probably going to have a problem, and definitely consider whether the auto paint will eat the plastic that these things are made out of. (I melted a helmet shell one time from using the wrong type of paint.)
On the other hand, if you use Rusto, you can just repaint them if they start looking flakey.
One more thought, which might address the flexibility is to potentially use dashboard paint - never tried it tho.
heehaw is offline
post #3 of 46 (permalink) Old 07-02-2008, 09:33 PM
You mean like this.
I just used Walmart brand flat black, $.89 a can. I just lightly sanded them then washed and dried them and painted them.
Baddone is offline
post #4 of 46 (permalink) Old 07-02-2008, 09:45 PM Thread Starter
Originally Posted by Baddone View Post
You mean like this.
Yep! That's exactly what I'm thinking!
So they're holding up OK? I've noticed that my boots are rubbing the color off the stock side panels as it is....
Since they're textured (or maybe it's called a metallic finish?) it seems like it will be hard to sand into the crevasses so the paint will stick.
post #5 of 46 (permalink) Old 07-03-2008, 09:28 AM
Krylon Fusion paint, made for plastic. No sanding, no priming, just wipe down with alcohol and paint.
Bill
Versys
F650GSD
FLSTSCI
XR650L
Tri Scrambler
XR50
SRX600
Zuma 125
T100R
Aero 50
EZ90
PA50
States by MC
Bad-Tat is offline
post #6 of 46 (permalink) Old 07-03-2008, 09:49 AM
x2. Rustoleum makes a plastic paint you can do the same way. I've used it in the past with great results/durability.
08 Versys is offline
post #7 of 46 (permalink) Old 07-06-2008, 04:33 AM
Something I used to do modding PC cases a lot was to use automotive Vinyl Dye. It's used to recolor vinyl dashboards, etc in cars. It's a superfine spray paint with a solvent mixed in that actually penetrates into the plastic. It's very easy to go darker in color, but not so easy to go lighter.
sartek is offline
post #8 of 46 (permalink) Old 07-07-2008, 03:02 PM
Painted mine this weekend with Krylon Fusion, looks great.
Bad-Tat,
I see you have a Fasma tank bag. Which one is it and how do you like it?
oscar.45 is offline
post #9 of 46 (permalink) Old 07-07-2008, 05:01 PM
Oscar,
It's the Famsa bag that fits the 1200GS. Perfect fit and it's great!! Just unzip from the base to fill with gas. That is a bit of a pain as I'm spoiled from the Dakar with that tank under the seat!
Bill
Versys
F650GSD
FLSTSCI
XR650L
Tri Scrambler
XR50
SRX600
Zuma 125
T100R
Aero 50
EZ90
PA50
States by MC
Bad-Tat is offline
post #10 of 46 (permalink) Old 07-08-2008, 12:04 AM
WillieFlo's Avatar
Prepped and painted mine with Krylon Fusion Black. See my pic...
WillieFlo is offline
post #11 of 46 (permalink) Old 07-08-2008, 12:26 AM
oxman's Avatar
Hey Willie , Did ya paint your rims as well or are they stock???? by the way it looks sweet !
Ox.......
oxman is offline
post #12 of 46 (permalink) Old 07-08-2008, 08:30 AM
WillieFlo's Avatar
Yep, I painted them as well with Duplicolor Acrylic Enamel in Glossy Black. Took a whole day to do because of all the prep and masking work, but it was worth it.
I was going to ues Duplicolor's Aluminum Wheel Paint, but they don't make it in Black from what I could find at the local O'Reilly's, Auto Zone, and Advanced Auto Parts shops, so I went with acrylic enamel because it's suposed to be harder than standard auto or Krylon paint....THANKS!
post #13 of 46 (permalink) Old 07-08-2008, 11:49 AM
GregScuba's Avatar
Looks good. Sometimes it's hard to tell from the pictures, but is it flat, satin, semi-gloss, or gloss?
GregScuba is offline
post #14 of 46 (permalink) Old 07-08-2008, 12:30 PM
WillieFlo's Avatar
Thanks. The can says Glossy Black but with the texture on the parts it looks more like semi-gloss. It matches the OEM Black piece that runs under the tank and seat almost perfectly.
post #15 of 46 (permalink) Old 07-09-2008, 03:00 PM
StonedGP's Avatar
You fellas used flat black paint, right?
StonedGP is offline
post #16 of 46 (permalink) Old 07-09-2008, 03:11 PM
WillieFlo's Avatar
Nope,
I used Krylon Fusion Glossy Black. It dries like a semi-gloss due to the texture on the pieces. It matches the Black ones from the factory perfectly because I applied shine protectant to them when I first got the bike.
post #17 of 46 (permalink) Old 07-09-2008, 03:13 PM Thread Starter
I decided to use the Satin Black (Krylon Fusion). The finish seems to match the other factory parts pretty closely...
I'll post some pictures when I can get a chance.
post #18 of 46 (permalink) Old 07-09-2008, 03:17 PM
StonedGP's Avatar
One more ?. Willieflo...did you use the same paint on the foot peg mounts? I noticed yours were black also. Considering they are made of aluminum.
StonedGP is offline
post #19 of 46 (permalink) Old 07-09-2008, 06:46 PM
WillieFlo's Avatar
Stoned GP,
For those foot peg mount plates, I actually used the Duplicolor Acrylic Enamel in Black Glossy after prepping:
1. Take off the shine with 800 grit sandpaper
2. Gave it a 1000 grit wet sanding
3. Washed it with a little Dawn & alot of water
4. Towel dry
5. Give it a Prep All cleaning to get rid of any oils or residue left
I did this same process to do the wheels and used the same Duplicolor Acrylic Enamel since its supposed to be harder than typical Krylon rattlecan paint.
post #20 of 46 (permalink) Old 07-09-2008, 08:23 PM
WillieFlo,
How did you get the tires back on the rims without chipping any paint? Do you have a touchless mag changer or something?
Your V looks good... hope you don't mind a look alike in South Florida.
Todd
Todd
tem1268 is offline
Similar Threads
Cracking plastic by mirrors archer183 Technical Discussion - V-650 14 12-22-2009 04:46 PM
Painting? RedRabbit Modifications - Cosmetic - V-650 19 09-10-2008 12:28 PM
Painting Hard Bag dlowry Modifications - Cosmetic - V-650 4 09-01-2008 08:56 PM
