Versys LED kits - Kawasaki Versys Forum
post #1 of 6 (permalink) Old 07-01-2008, 10:01 AM Thread Starter
Versys LED kits
I may be a safety freak but I feel like I should be more visible when riding my Versys, day or night. Does anyone have experience selecting and installing LED kits (brake, turn, front, rear, whatever makes you more visible) and provide recommendations?
Thx
Daniel
FouDuFafa is offline
post #2 of 6 (permalink) Old 07-01-2008, 01:28 PM
Hooligan's Avatar
The best LED turn signals I have ever bought or seen (best quality and brightest) are Kellerman. They are a little expensive, but well worth it.
http://www.spieglerusa.com/cfm/kellermann.cfm
Graham
To do is to be. -Descartes
To be is to do. -Voltaire
Do be do be do. -Frank Sinatra
States I've ridden in so far
Hooligan is offline
post #3 of 6 (permalink) Old 07-01-2008, 08:31 PM
I installed the back off module on the rear led brake and it is an attention getter. Soldering all connections it only took 30 minutes.
http://www.signaldynamics.com/products/Modules/xp.asp
For piece of mind I poked little led bulbs in all of the blinkers to use as running lights which took quite a bit more time to install; and a few more beers. They give off moderate light but running straight led blinkers as turn signal and running lights would be the brightest.
One of the other threads talks about putting the somewhat pricey 65 watt H7 bulbs in the front for a huge difference in headlight output... that is next on the list.
http://www.suvlights.com/product_inf...roducts_id=164
Hope this helps
Todd
tem1268 is offline
post #4 of 6 (permalink) Old 07-02-2008, 06:07 PM
Dorian's Avatar
I found these, http://www.kisantech.com/index.php?cat_id=1 . They look like a great way to let everyone else know what your intensions are. I don't know if the price is too much or not, but they do look interesting.
Dorian is offline
post #5 of 6 (permalink) Old 07-02-2008, 06:12 PM
Dorian's Avatar
BTW, I don't know about other states but in New Hampshire you can not replace any lights with anything other then manufacturers design. This does not mean you you can't add supplemental lights. I know of several people who were stopped by the State Police and told they had to change the LED lights back to stock. I don't know what other state allow.
Dorian is offline
post #6 of 6 (permalink) Old 07-04-2008, 01:31 PM
Check out my LED's under Versys modifications. Work great, look good and a cheap price.
chazzman is offline
Similar Threads
Body kits? myorangecamaro Modifications - Cosmetic - V-650 4 08-25-2008 09:33 PM
Beak kits for Versys? dasgreif Modifications - Cosmetic - V-650 4 08-02-2008 06:04 PM
