YAMASAKI tall touring windshield-cheap - Kawasaki Versys Forum
post #1 of 33 (permalink) Old 11-15-2009, 06:27 PM Thread Starter
blipco's Avatar
Alright, I'll admit it, my other bike is a scooter. A 2007 Yamaha Majesty 400.The factory shield offers little in the way of wind protection when used on the scooter. Most owners go to a much larger screen to get a comfortable ride as did I. I tried to sell it on the Majesty site but no one buys them, why would they. I've seen them offered for as little as 30 dollars with no takers. Then a light went on. A little cutting, a little drilling. Here is the result. At 90 mph (actual) I was able to lift my helmet face plate with no wind coming in. After a three hour ride, no bugs on my helmet. It doesn't look bad on the bike. I cut away as little as possible to make it fit. Pictured are the pieces I cut away to clear the mirrors, about 1 1/8 inches per side.There is a detail in the shield which makes room for the brake and clutch levers so this determined the mounting height. I used a coping saw and a coarse and fine 1/2 round files and fine grit sand paper. Easy. It measures 16 1/2 inches from the top mounting hole of the factory mounts and 16 inches wide at the top. About 17 wide at the bottom.Maybe 25 0r 26 inches long over all. I'm a shade under 6 feet tall with a 33 inch inseam and I can look over the top. There are plenty for sale on the Majesty site if interested.
blipco is offline
post #2 of 33 (permalink) Old 11-15-2009, 08:37 PM
sambamboo's Avatar
Thats an awesome piece of lateral thinking Blip...just curious tho, do you recon the mirrors would clear the screen with extenders attached? as that would save a lot of work on the cutting.
sambamboo is offline
post #3 of 33 (permalink) Old 11-15-2009, 08:47 PM Thread Starter
blipco's Avatar
Yeah, I'd bet they would. I cut 1 1/8" and at full lock I still have a 1/2" or so. You would still have to trim the bottom a little. The cutting is real easy though. Quality screen it is. The toughest part is getting your lines and trying to hold the thing while working on it. A second pair of hands would be good. I stretched a string between the original mounting holes in the screen for a reference point for drilling the four holes needed for attachment to the V.
blipco is offline
post #4 of 33 (permalink) Old 11-15-2009, 08:49 PM Thread Starter
blipco's Avatar
Here is the website. majestyusa.com
blipco is offline
post #5 of 33 (permalink) Old 11-15-2009, 09:18 PM
Could you have just put the factory screen on top of this one and marked the mounting holes? I am impressed.
Highpsiguy is offline
post #6 of 33 (permalink) Old 11-16-2009, 08:46 AM
brothercannon's Avatar
nice work, I'm betting with my set-up (mirror wideners, and bar risers in a backward position) no side cutting would be required at all. Even though I have a Givi windscreen this looks tempting.
brothercannon is offline
post #7 of 33 (permalink) Old 11-16-2009, 10:48 AM
LoneRanger's Avatar
I love modifications that are cheap and work well. So I went by the Majesty site last night and found a stock windscreen for $25 shipped. It is on its way. I will take photos of my screen modification as it progresses and then report on its functionality. For $25, some cutting and modifying - seems worth it to me.
LoneRanger is offline
post #8 of 33 (permalink) Old 11-16-2009, 04:18 PM Thread Starter
blipco's Avatar
Possibly but I wanted the original contours to mate up with the levers. I held it in place with one hand and made a mark with a marker with the other then drilled one hole, then repeated for each hole.
blipco is offline
post #9 of 33 (permalink) Old 11-16-2009, 04:24 PM Thread Starter
blipco's Avatar
Good job, there are many more to be had like that. It's not a bad looking wind shield. Better than many after market screens. IMHO. I like mods that move junk out of my attic. I'm up in the air as to the Yamaha symbol. Maybe I'll just leave it to further confuse people as to what it is I'm riding.
blipco is offline
post #10 of 33 (permalink) Old 11-16-2009, 09:06 PM
Awesome and looks good
post #11 of 33 (permalink) Old 11-17-2009, 06:37 AM
E-nigma's Avatar
Nice handiwork with modest tools.
That screen sure is tall. Can you see over it or do you have to look through it?
It changes the lines of the bike quite a bit. I think it would look better if the top edges weren't flared out and it was about 4 inches shorter.
E-nigma is offline
post #12 of 33 (permalink) Old 11-17-2009, 04:31 PM Thread Starter
blipco's Avatar
E, I'm not sure I'm done trimming it. I plan only to use it in cold weather and long trips. The pictures make it look taller than it actually is. It is a tall one though. I look over the top, if I run my hand up, the wind hits about the top of my helmet. If I lean close to the shield it's dead air. I'm 5'- 11 1/2" with a 33" inseam. I used to think cutting a windshield was a dark art but it turns out to be no big deal. Even with old school tools. When was the last time you saw a coping saw ?
blipco is offline
post #13 of 33 (permalink) Old 11-17-2009, 04:42 PM
LoneRanger's Avatar
High school shop class. But I remembered what it was. I cut down my cruiser shield making it 5 inches shorter. I taped the line, used a dremel on low speed to make a impression line, then used a sabre saw on med speed with medium pressure to cut the line. Carefully sanded the edge with 1000 grit sandpaper, and polished it with McGuires plastic polish. The edge looks better than factory. Cutting a shield sounds scary, but it is really a simple easy job.
Here is the cutdown windscreen on my Harley Fairing mounted to my Honda VTX.
post #14 of 33 (permalink) Old 11-20-2009, 04:29 PM Thread Starter
blipco's Avatar
LR, nice work. Looks like you have a Harley that doesn't break down.
blipco is offline
post #15 of 33 (permalink) Old 11-25-2009, 08:09 AM
LoneRanger's Avatar
I purchased the Majesty windshield from a contact in Denver from the Majesty owners forum. Total cost $25 shipped! What a deal. I sawed off the Majesty mounting tabs. Used my old windshield as a template for drilling the bolt holes and installed it last night. I rode to work this morning (48 degrees F) and what a difference. This makes a great inexpensive touring windshield. I hit 90 mph on the way to work as a test - no buffeting, I was warm and protected. WHAT A DEAL! For $25 I have a $200 modification that really works. It looks a little funky when you are not on the bike, but the protection is fantastic.
Even though it is much larger than the stock shield, it sits firm and steady. No shaking or vibration.
I mounted it so the top of the shield is chin height for me (I am 5-10). I will have to trim some off the front bottom point as it covers the headlight a little.
When all modifications to the shield are complete, I will post pictures.
UPDATE: I was not happy with how tall the windshield is, so I cut off 2.5 inches off the top. It is a much nicer ride now - the shield does not bounce as much and it fits the bike better. Great mod!
post #16 of 33 (permalink) Old 11-25-2009, 07:20 PM Thread Starter
blipco's Avatar
My mounting height was determined by the cut outs which made room for the levers. You had no clearance issues with the levers at full lock ? As a result it put the top of the shield just below my sight line and above my chin. I'm just under six feet. You lucked out on the price though most Maj owners must be tired of looking at the shields laying around the house. That scoot goes a hundred MPH !
blipco is offline
post #17 of 33 (permalink) Old 11-30-2009, 10:26 PM
LoneRanger's Avatar
Here is result. I will need to make some side modifications to make room for the hand guards. I lowered mine to make the front look mean. The top of the shield is even with my chin and I am 5'10. Works great, looks good.
post #18 of 33 (permalink) Old 12-01-2009, 09:02 PM Thread Starter
blipco's Avatar
Sweet. That was my first choice of position then I decided I liked the bottom shape of the shield so I raised it. Keep in mind I was afraid to cut it having never done so. Looks like a contour cut to the headlight shape and you'll have a custom shield. Does it really block the light ?
blipco is offline
post #19 of 33 (permalink) Old 12-02-2009, 12:01 AM
Thanks blipco!! Great idea! Man I love this forum! I too have a used 2007 Majesty 400 screen coming from a nice guy in Ohio who I found through the Majestyusa forum. $50 + shipping for a mint screen. Will post after I receive it and get it mounted in about a week or so. Thanks again!!
MeenGreen is offline
post #20 of 33 (permalink) Old 12-02-2009, 11:20 AM
LoneRanger's Avatar
I didn't notice any light blockage - but I always ride with the driving lights on. I did get some reflective light on the inside of the shield that was a little annoying. I will have to modify it to rectify the reflection issue.
