rear turn signal question - Kawasaki Versys Forum
post #1 of 8 (permalink) Old 05-15-2014, 05:08 PM Thread Starter
chadams66's Avatar
I'm going to be mounting some Givi Trekker cases...This involves moving the rear turn signals...I can't quite figure out how they come off and..of course..I don't want to break anything by being ham fisted...Anyone out there ever done this?
chadams66 is offline
post #2 of 8 (permalink) Old 05-15-2014, 05:56 PM
Mac-man's Avatar
Yeah it's pretty simple. The taking off anyway. There is a plate on the inside of each signal held in place by one screw (Phillips I believe). Remove the screw and pop that plate out and the signal is free to be wiggledout of the hole.
Assuming your cases came with directions to relocate them, the rest should be covered there.
Luck favors the prepared.
Mac-man is offline
post #3 of 8 (permalink) Old 05-15-2014, 06:48 PM Thread Starter
chadams66's Avatar
thanks...I thought I felt a plate back there...I'll pull the whole fender off for better access...Yes the Givi mounts came with all the instructions needed..the job looks like it'll take about an hour...
post #4 of 8 (permalink) Old 05-15-2014, 06:55 PM
Please take notes on how many new curse words you invent trying to wiggle them back into the new relocation plate.
adurbin is offline
post #5 of 8 (permalink) Old 05-15-2014, 09:12 PM
BLACK DOG's Avatar
lubrication is your friend
BLACK DOG is offline
post #6 of 8 (permalink) Old 05-15-2014, 09:53 PM Thread Starter
chadams66's Avatar
that's what a friend tried to tell me once..
post #7 of 8 (permalink) Old 05-15-2014, 10:14 PM
BLACK DOG's Avatar
a friend will warn you of trouble
a good friend will throw your bail
a true friend will be in the cell next to you telling you how cool it was
post #8 of 8 (permalink) Old 05-24-2014, 02:31 AM Thread Starter
chadams66's Avatar
spent around 3 hours this afternoon (5/23/14) and got the Givi mounts and cases put on...repositioning the rear turn signals definitely involved removing the rear fender..but was fairly easy..you have to unplug them from the wiring harness also...a bit of a stretch to get all the wiring back in place..but it all works out nicely...the Givi mounts and parts went on smoothly enough..if you remember not to tighten everything down snuggly until after it's all together...some pulling..grunting and then finally it just all comes together...the cases look pretty good..but I'm considering getting some paint and painting the aluminum parts matching the "pearl solar yellow"...
