My cheap auxilliary brake lights. - Kawasaki Versys Forum
post #1 of 9 (permalink) Old 04-07-2014, 12:00 PM Thread Starter
Got two 3" SMD LED light strips from fleabay user Lone Star Truck Gear for a few bucks. I don't recall exact $$$, but it was cheap.
I am very pleased. I didn't have black wire loom, so ignore the light plastic umbilicus.
HVMP is offline
post #2 of 9 (permalink) Old 04-07-2014, 05:16 PM
Did you "mask" your license plate before posting the picture or is that how a NY plate appears when photographed? Whichever, that's pretty cool.
post #3 of 9 (permalink) Old 04-07-2014, 05:21 PM Thread Starter
I just scrambled it a little with a photo-editing tool.
HVMP is offline
post #4 of 9 (permalink) Old 04-07-2014, 08:26 PM
I've been blinded!!!!
Gigitt is offline
post #5 of 9 (permalink) Old 04-07-2014, 08:41 PM Thread Starter
For sure. They do great. Put a set on the SV as well. I just ordered 6" white strips for the upper fork tubes. Can't be too conspicuous when you're on the road.
HVMP is offline
post #6 of 9 (permalink) Old 04-14-2014, 10:32 PM
andrewhtf's Avatar
This is what i did.
pretty cheap and no, it aint gonna blind the bejessuz out of anyone behind me.
Current : Maroon 2011.
Up next :
andrewhtf is offline
post #7 of 9 (permalink) Old 04-15-2014, 07:30 PM Thread Starter
Real world results:
Not too bright during high noon, but will do the job fine at dusk or in the dark.
HVMP is offline
post #8 of 9 (permalink) Old 04-15-2014, 07:43 PM Thread Starter
Originally Posted by andrewhtf View Post
This is what i did.
I don't have my Givi mounting plate on it yet, or I would have done exactly what you did.
HVMP is offline
post #9 of 9 (permalink) Old 04-17-2014, 04:29 AM
andrewhtf's Avatar
when you do, get a strip made from 5050-type SMD LEDs. they can be seen better in daylight compared to this strip i am using.
Plus, the strip should be less than a foot. between 9-10inch would be ideal. if you use full 12-inch strip you 'd get excesses at the sides that wont stick to the Givi base plate and peels off on its own.
Up next :
