Moving my rear turn signals - Kawasaki Versys Forum
post #1 of 4 (permalink) Old 03-27-2014, 11:18 PM Thread Starter
Mac-man's Avatar
I read a couple threads on here about moving the rear blinkers so they don't hit my soft bags and figured I'd give it a shot! So this is a little combination of what I did today and if it helps anyone else that wants to try it, great!
Coming apart wasn't hard at all, one screw and a small bracket. The wiring under the seat came unplugged with a little bit of encouragement.
I cut a stencil out of a post card and used an expo marker to trace it so I could wipe it off after.
No dremel tool available so i used a little drill bit in a cordless drill. I found that the handle of a ratchet worked better than sand paper to sand down the rough edges.
I did have to extend the wiring for the left hand side about 3 inches. The right side was longer and I ran it up under the seat on the near side so it reached.
(forgot to take a picture of that)
The first side took an hour or more, but the second side only took about 15 minutes since I figured out what I was doing and didn't have to mess with the wiring.
While I was messing around back there I decided to trim the fender with a coping saw just above the bottom of the license plate so it didn't look so stupid!
Mission accomplished! Now I can see my turn signals! And more importantly, so can everyone else.
Luck favors the prepared.
Mac-man is offline
post #2 of 4 (permalink) Old 03-27-2014, 11:21 PM
KLR 650 Signals are shorter. No cutting necessary.
post #3 of 4 (permalink) Old 03-27-2014, 11:29 PM Thread Starter
Mac-man's Avatar
Didn't know that!
This was pretty much free though because I just used what I had laying around. I don't have a set of those laying around...
Mac-man is offline
post #4 of 4 (permalink) Old 03-27-2014, 11:35 PM
Originally Posted by Mac-man View Post
Didn't know that!
Some have cut the stock signals down.
