Modifications on new '09 - Kawasaki Versys Forum
post #1 of 16 (permalink) Old 09-19-2009, 08:47 PM Thread Starter
E-nigma's Avatar
We recently purchased a new Green '09 for my wife, and I thought I would share some pics of the mods I have made to it.
Eastern Beaver PC8 Fuse Panel mounted on home-made bracket. Also shown; relays powering fuse panel and Stebel Nautilus horn
PC8 and tail-light splice for triggering fuse panel relay
Inside PC8
Backoff brake light modulator hidden under PC8
Back-side of mounting bracket for PC8
Barkbusters Storm handguards. "Side-wings" on Givi windscreen had to be removed to allow handguard clearance. Also shown; Oxford heated grips powered by FirstGear Heatroller. I decided not to use the Oxford heat controller after reading about the potential "power-offs" due to low voltage input.
Heatroller mounted on home-made bracket under SW-Motech mirror wideners.
Stebel Nautilus mounted under left side fairing
Home-made bracket using stock threaded mounting point on bike
Tight clearance next to tank is necessary to also clear inside of fairing
Powerlet socket on home-made bracket for powering heated clothing
MotoWerk lowering block
Clamps lowered in fork tubes
Another shot of clamps lowered in fork tubes
Shorter sidestand necessary for lowering kit install with larger foot welded on sidestand
E-nigma is offline
post #2 of 16 (permalink) Old 09-19-2009, 08:48 PM Thread Starter
E-nigma's Avatar
continued...
Givi PL447 luggage racks
Upper rack mounting point shown. The "under-seat" bracket is not included in the PL447 side-rack kit and must be purchased separately. It is also included in the top-rack mounting kit as an alternative.
I shortened the stock turn signals so they would clear the racks and luggage without having to use the ugly Givi signal relocation brackets
H&B Crashbars
Lower crashbar mounting point is strong, using the engine/frame mount
I chose the H&B crashbars because none of the other brands had a joiner plate between the right and left sides of the crashbars
I dislike the rear mounting point of the crashbars; too small of a bolt in my opinion
Woodcraft slider spools
E-nigma is offline
post #3 of 16 (permalink) Old 09-19-2009, 08:50 PM
tuxkat's Avatar
Nice job on the additions
"If everything seems to be under control, you're not going fast enough."
Mario Andretti
tuxkat is offline
post #4 of 16 (permalink) Old 09-19-2009, 09:21 PM
Nice job & great pics!
post #5 of 16 (permalink) Old 09-19-2009, 09:34 PM
blipco's Avatar
Good stuff. I see you take pride in your work.
blipco is offline
post #6 of 16 (permalink) Old 09-19-2009, 10:41 PM
Hi E-nigma,
Nice mods and pics. Congrats on your V and Have a Good time!
post #7 of 16 (permalink) Old 09-19-2009, 11:27 PM
Wow, you do nice work!
Gary
2009 Candy Plasma Blue Versys
BarkBuster Handguards
Eastern Beaver fuse box
Ermax Rear Hugger
Garmin Zumo 660
Givi V35 Side Cases, V46 Top Case (with AdMore Lighting LEDV46-T-TS)
Motowerk Flat Foot, GPS Mount, Mirror Extenders
Pyramid Fenda Extenda
Stebel Nautilus Horn
SW Motech Crash Bars
Aprilia Tuono mirrors
GoGary is offline
post #8 of 16 (permalink) Old 09-20-2009, 06:04 AM
jnor's Avatar
Good job............great pics....
'15 DL1000
jnor is offline
post #9 of 16 (permalink) Old 09-20-2009, 09:27 AM
Very good quality pics!!
Your craftsmanship shows!! You obvoiuosly work with your hands for a living.
Randy49 is offline
post #10 of 16 (permalink) Old 09-20-2009, 12:25 PM
Lovely work as the others have said!
Only POSSIBLE issue I see: your 12V powerlet's wires are apparently in a compromised position above your rear tire (when rear suspension compresses). Or is that an illusion?
post #11 of 16 (permalink) Old 09-20-2009, 01:13 PM Thread Starter
E-nigma's Avatar
Good point and good observation, and I did think about that when installing the socket. There will be enough clearance (about 4 inches before compression from bottom of socket to top of swingarm brace).
E-nigma is offline
post #12 of 16 (permalink) Old 09-21-2009, 02:51 PM
You do really nice clean work. Wish u lived close to me so I could pick your brain. Nice bike and nice pics.
rhrose is offline
post #13 of 16 (permalink) Old 09-28-2009, 11:50 AM
FJS
FJS's Avatar
Thumbs up
Congrats on the bike and all the work you put in to it for your wife, really shows you care about what you are doing. Hope you both enjoy the rides.
FJS is offline
post #14 of 16 (permalink) Old 10-06-2009, 09:35 PM
flienlow's Avatar
Nice clean job.
Question:
I keep seeing "Relay" for this ,and that. Why are relays used on this bike for such things as lights and ect.
flienlow is offline
post #15 of 16 (permalink) Old 10-07-2009, 05:44 AM Thread Starter
E-nigma's Avatar
Originally Posted by flienlow View Post
Nice clean job.
Question:
Relays were used for two reasons:
1. If the new fuse panel had been wired directly to the battery, then any accessories wired to the fuse panel would always be on, even when the bike's ignition is off. With this set-up the accessories could drain the battery. This was prevented by placing a relay in-line between the battery and the fuse panel. The relay has four connection terminals. One goes to the battery, one goes to the fuse panel, one is grounded to the frame, and the final terminal goes to the bike's tail-light wire. When the bike is turned on, the tail-light wire becomes "hot", triggering the relay to turn on by closing the circuit from the battery to the fuse panel, and the fuse panel and it's accessories become powered.
2. Another relay was used for the Stebel horn, as it draws up to 15 amps of current. This is more current than is drawn by the stock horn. If you were to run this much current through the horn switch on the handlebar, the small contact points in the switch could become damaged with enough use. By powering the horn with a relay, the horn switch does not run these high amps, but instead triggers the relay to turn on, closing the circuit from the fuse panel (battery) to the horn. The relay runs the high amps, not the switch on the handlebar. Since the horn is connected to the new fuse panel, it is actually power by two relays, one that powers the fuse panel, and another that is triggered by the horn switch on the handlebars. There are also two horn fuses to look at if the horn stops working, the fuse in the OEM fuse panel that powers the handlebar switch, and the fuse in the new fuse panel that powers the horn relay.
Horn and relay wiring diagram (the "battery" in this digram is actually the new fuse panel, and the "+ and - factory horn leads" are connected to the handlebar switch in my set-up).
E-nigma is offline
post #16 of 16 (permalink) Old 10-07-2009, 07:53 PM
flienlow's Avatar
AWWW! We have comprehension now. Thank you for the excellent explanation.
flienlow is offline
