Electrical upgrades - Kawasaki Versys Forum
LinkBack Thread Tools
Old 03-17-2014, 03:01 AM Thread Starter
Electrical upgrades
I wanted to reinstall my Wolo Bad Boy air horn (mounting bracket broke), run the wires for my AME heated grips, add LED daylight running lights, install an Narva 81134L accessory USB outlet and install my FuzeBlock.
I took the fuel tank off and all the plastics from the seat forward so I could run the wires without them being seen. I ended up also removing the instrument panel and headlight unit.
I removed the tool kit so I could mount the FuzeBlock close to the battery after checking to see it (tool kit) would fit in front of the tail light. I placed a piece of rubber to protect the FuzeBlock and strapped it down with the rubber strap which normally holds the tool kit. Ran the Battery wire to the Battery positive terminal, the earth I Posi-Tapped into one of the earth wires next to the spare fuses and the switched power I picked up using another Posi-Tap to the tail light.
The heated grips wires joined the air horn wires attached to the battery, I suspect the current draw would be too much for the FuzeBlock and both have their own fuse.
Heated grip plugs
The LED lights draw 300 milliamps so I ran them direct off the low beam feed again using a Posi-Tap and earthed them on a nearby bolt.
The USB outlet runs through the FuzeBlock using a 5 amp fuse and switches off and on with the key. Good thing about the FuzeBlock is if I decide I want it on all the time I just move the fuse to the constant on position takes a minute to do.
That was my weekend how was yours?
Old 03-17-2014, 08:39 AM
You wired up the Positive OK to the battery, so Why did you Positatp the Earth? This is wrong.
You need to have as good an earth as the positive. You also need to make sure that the earth wire is capable of MAX current amperage - and you have just added to an existing earth wire system.
Behind the tool bag area and on top of the ECU is the seat locking mechanism frame and here you should find a nice earth bolt already in use. I would suggest you use this instead.
Gigitt is offline
Old 03-18-2014, 12:21 AM Thread Starter
Thanks for the input and I agree however just now I only have the USB socket attached to the FuzeBlock so I'll leave it as it is. If I add more devices I'll fix the earth as you suggested.
