Help removing adhesive... - Kawasaki Versys Forum
post #1 of 13 (permalink) Old 02-19-2014, 09:00 AM Thread Starter
Zatx's Avatar
So I had a tank scratch guard thing-a-majig on my gas tank. After a year and a half it started to come off so I pulled it the rest of the way off. It left the usual residue behind.
What do you guys use to remove this without damaging the paint? On glass I use Goop-off and a razor blade. That isn't really an option for this. I tried rubbing alcohol, but it did nothing.
Zatx is offline
post #2 of 13 (permalink) Old 02-19-2014, 09:06 AM
RN Barb's Avatar
Use a product called Goo Gone. That takes all the adhesive residue off really well. I buy it at any hardware store in Canada so hopefully it is available to you as well.
RN Barb is offline
post #3 of 13 (permalink) Old 02-19-2014, 10:07 AM
+1 for RN Barb's suggestion regarding Goo Gone. It will remove residue from almost anything without causing damage. It might take more than a little rubbing if the adhesive is thick but in the long run it works well. I wouldn't suggest using anything to scrape the surface - just keep rubbing and turn the cloth frequently. After removing the adhesive you might try using Windex or some other mild cleaner to remove the Goo Gone film left behind - it's rather oily. Then polish and wax the area - good as new.
post #4 of 13 (permalink) Old 02-19-2014, 10:09 AM
El Tig's Avatar
+2 for Goo Gone but you might already have another 'solution' on hand....wd40!
http://tutorialgeek.blogspot.com/201...glue-with.html
El Tig is offline
post #5 of 13 (permalink) Old 02-19-2014, 10:19 AM
baby oil works too.
post #6 of 13 (permalink) Old 02-19-2014, 10:20 AM
goat12's Avatar
My vote is for WD-40. Have yet to meet a sticker it couldn't remove the residue of...
goat12 is offline
post #7 of 13 (permalink) Old 02-19-2014, 11:01 AM
I know it is wrong but I always use gasoline.
turn8a is online now
post #8 of 13 (permalink) Old 02-19-2014, 11:04 AM
I talked to fasteddie and he said he likes WD40.
post #9 of 13 (permalink) Old 02-19-2014, 11:18 AM
I've had good results with honda spray polish. When removing stickers, a bit of heat from a hairdryer helps. Test the other products first, I'd be concerned that gas will dull the paint.
HondaGalToo is offline
post #10 of 13 (permalink) Old 02-19-2014, 01:47 PM
I have done the de-badge/re-badge cycle on my V seven times now, always using Goo Gone. Works great
post #11 of 13 (permalink) Old 02-19-2014, 02:16 PM
I will definitely try WD 40!
trialsguy is offline
post #12 of 13 (permalink) Old 02-19-2014, 06:56 PM
You guys ALL jumped in BEFORE I could say...
WD40.
It just plain WORKS...!
(And good for your chain TOO.)
post #13 of 13 (permalink) Old 02-20-2014, 07:40 AM Thread Starter
Zatx's Avatar
Thanks guys.
Zatx is offline
