My Single Bi-Xenon Projector Retrofit (Pic Heavy) - Kawasaki Versys Forum
post #1 of 9 (permalink) Old 02-10-2014, 12:54 PM Thread Starter
It's finally done! I started this retrofit a month or so ago with the reflector out of a cracked headlight I had laying around. Due to TRS fudging up my order twice (2 wrong harnesses, 2 wrong high beam splitters, 2 shrouds with defective chrome) with a winter storm in between, I had plenty of time to get everything the way I wanted. It started like this:
High beam splitter modified with H4 connector. I should note, I ended up using a standard H7 harness with the stock H7/H4 adapters.
I decided I wanted to paint the reflector bowl satin black for a clean look and less glare.
Satin black for the cutoff shield as well. Makes the projector look blacked-out with the light off.
GTI-R shroud modified for clearance and painted silver. I wanted it chrome, but on both shrouds they sent, it rubbed off just by touching it.
After trying it the way it was intended, I discovered the headlight lens hits the projector, no bueno. I had to get the dremel back out. It looks like rubbish, but it's actually more secure and looks better this way.
Ballast mounting:
The fruits of my labour...
2009 Versys - Daily Driven
TypeRated is offline
post #2 of 9 (permalink) Old 02-10-2014, 04:26 PM
Thaylin's Avatar
That looks great! Do you have any night pics looking out across the beam to see how it lights up?
-Compiled by an Android-
I ride to get lost and find my way back.
Thaylin is offline
post #3 of 9 (permalink) Old 02-10-2014, 04:30 PM Thread Starter
I'm going to try to get some pics of the output and cutoff tonight
post #4 of 9 (permalink) Old 02-10-2014, 10:37 PM
Me likey.
Gigitt is offline
post #5 of 9 (permalink) Old 02-11-2014, 12:10 AM Thread Starter
I had to drive outside of town to find an unlit road and get a couple shots, but I managed to do it without freezing. I still need to fine tune the alignment, but it's close.
Low beam:
High beam:
Cutoff:
post #6 of 9 (permalink) Old 02-11-2014, 07:51 AM
Thaylin's Avatar
I'd say that is very nice. Great job! Thanks for the post
Thaylin is offline
post #7 of 9 (permalink) Old 02-11-2014, 05:43 PM
chid's Avatar
good job!
now enjoy the cut-off when you lean the bike
Versys 2015 Green
chid is online now
post #8 of 9 (permalink) Old 02-12-2014, 12:07 AM Thread Starter
Thanks guys! I'm pretty proud of my handiwork. I can't wait to get it properly aligned. The only hold up is a place to do that.
post #9 of 9 (permalink) Old 02-12-2014, 08:39 AM
Lours_Polaire's Avatar
Very nice integration to the original desing !!!
LOP
Lours_Polaire is offline
