High front fender - Kawasaki Versys Forum
post #1 of 67 (permalink) Old 07-16-2009, 10:22 AM Thread Starter
MountainMan's Avatar
High front fender
Hey folks, I installed a new front tire and now I have to raise the front fender for proper clearance. I could raise it just enough to clear the new tire but I like the look of the BMW's and Buell front fenders. Attached are a couple of pix to show you what I'm talking about. There are a few issues I can see but none that I can't fix. The rear portion does clear the raidiator. One of the main issues I see are the brake lines. I haven't quite figured out waht to do with them yet. Anybody see any other problems that will be hard to solve? Right now the fender is zip tied on for looks.
MountainMan is offline
post #2 of 67 (permalink) Old 07-16-2009, 11:30 AM
oxman's Avatar
Put a set of braided brake lines and do you split at the master cylinder and they should work great .
oxman is offline
post #3 of 67 (permalink) Old 07-16-2009, 02:53 PM
what size and type of tire did you put on the front. Are you trying to make it a little more off road worthy (adventure style). I am presently thinking of a Versys in the spring but and just trying to figure if i can get it fire road, logging road, minor water crossing worthy. I have both a road bike as well as a offroad bike for the real ruff stuff but am looking for somthing to make some trips on. If anyone has one set up for this type of riding please post some pics and a list of mods
thanks
buckshotsktm is offline
post #4 of 67 (permalink) Old 07-17-2009, 04:52 PM
I just road for three hours on fire roads in the Rocky Mountains near Denver on my stock Versys. This is basically a dirt bike pretending to be a street bike. The handling and balance off road is exceptional. Not a motocrosser but even with stock tires you can go all kinds of off road places. With a change to hybrid tires you would certainly be set. KB
blueversys is offline
post #5 of 67 (permalink) Old 07-17-2009, 04:53 PM
post #6 of 67 (permalink) Old 07-17-2009, 06:37 PM
Trailslapper's Avatar
Looks Good Mountainman. I think it looks great mounted up under the fork clamps. Makes you wonder why Kawasaki didn't do this straight from the factory.
I'm kinda in the same process right now. I actually have braided brake lines coming. 2 seperate lines coming from the Master so no concerns with the crossover. I'm going to mount a supermoto style fender from Polisport (only about $25 Cdn). Then for simple, but effective fork protectors, I'm going to attempt to rig up some ATV heavy Nylon shock covers. I'll post pics when/if it all comes together!!!
Trailslapper is offline
post #7 of 67 (permalink) Old 07-17-2009, 08:22 PM
ISLANDER1089's Avatar
Trailslapper, you might consider using motocross fork protectors suited for "upsidedown" forks as used on the Kawi KX models. With any luck they could be simple bolt-ons.
"life is not a dress rehearsal"
ISLANDER1089 is offline
post #8 of 67 (permalink) Old 07-22-2009, 11:07 PM
I don't think they'd easily fit Islander as the mounting points appear to me to be different. If anyone out there knows otherwise and has tried or has found another solution, I'd like to see it though
Just put on the Hel dual brakelines and the heavy nylon shock protectors. I haven't ridden with the protectors yet, hope they hold up, all LOOKS clear. Also added a Polisport motard fender, painted it a textured black to match the other black bits on the bike. I figure when the stock tires roll over and die, I'll now be able to fit the beefier sized Tourances.
Farkle on Brothers
post #9 of 67 (permalink) Old 07-22-2009, 11:38 PM
Have to say MountainMan and Trailslapper V looks GOOD
Reminds me of my old GS.
MountainMan,
What mirror have you got there?
Braided lines will be stylish and great for stoppies.
Thanks.
post #10 of 67 (permalink) Old 07-23-2009, 03:30 AM
Trailslapper, I kinda like that setup.
jhedges is offline
post #11 of 67 (permalink) Old 07-23-2009, 06:22 PM
Robzilla's Avatar
That is a wicked look with the high fenders and aggressive tires. Sorry, no real suggestions, just love the mean look.
Robzilla is offline
post #12 of 67 (permalink) Old 08-13-2009, 10:23 PM Thread Starter
MountainMan,
Thanks.
Stlee29, sorry for the late response but those mirrors are from a KLX 250SF from Kawasaki. They look a little more agressive than the stock square ones.
post #13 of 67 (permalink) Old 08-14-2009, 12:33 PM
gti20vturbo's Avatar
Farkle on Brothers
Questions...
1) Where did you get the dual brake line setup? Speigler will not make me a set, they only have a cross over setup for the Versys.
2) How is that fender mounted to the lower triple?
ST1300, Versys, SV650S
gti20vturbo is offline
post #14 of 67 (permalink) Old 08-14-2009, 12:48 PM
Hey GTI
Heres the guy who I bought the Hel lines from. Awesome seller and stoopid-fast shipping. He sells a race kit (with the 2 seperate lines from the master) and an over the fender (like stock) kit.
http://cgi.ebay.ca/KAWASAKI-VERSYS-6...d=p3911.c0.m14
I drilled 4 mounting holes in the fender, then made a thin aluminum bracket to go OVER the lower triple clamp, running bolts down through the holes in the fender. Theres very little room between the cable guide on the right hand side and the clamp when bars are turned to full right lock, so a little "tweaking" was required. It's rock solid and I didn't have to drill into the clamp at all.
The close up pictures are a bit blurry, I'm no photographer.
I've also considered Islander's thoughts and made a set of KX fork protectors fit as I wasn't entirely happy with the nylon ones. For this, I modded the inside stock metal fender mount to hold it all together. Then sprayed the works with a textured black paint to match the hugger and other bits, ...Whew.
Oh and I also added the Galloping Canadian Moose decals to the front
post #15 of 67 (permalink) Old 08-14-2009, 01:49 PM
Thank you thank you! I already ordered my fender and now I am off to get the brake lines. Those pics and explanation clear it up for me. Thanks again.
The TKCs should fit well now.
What kind of paint did you use? Did it seem to stick to the plastic well?
post #16 of 67 (permalink) Old 08-14-2009, 06:55 PM
Ahhhh the paint, thats a whole other experiment. I first lightly sanded the part, just enough so it isnt shiny. A little mouse sander works good and only takes about 5 mins. Then clean it reaaal good with something that removes greasey fingerprints and residue. I used sunlight dish soap. Then I hit it with a krylon textured black rattle can which bonds to plastic really well. The problem was that the color was more copperish then black. So I just sprayed over it with tremclad textured (not hammered) black. I think because the first coat was so rough, the tremclad bonded really well to it.
Let me know how the TKCs work out for ya. There won't be much out there that'll slow you down with those on!!
The fender comes in a shiny black anyway, and some people like it just the way it is too.
post #17 of 67 (permalink) Old 08-16-2009, 12:01 AM
The Canadians on WebBikeWorld have been using the Pirelli MT60 Corsa for adventure biking. They are doing more off road evaluations. See http://www.webbikeworld.com/motorcyc...ys/windscreen/ to catch up on the evaluation in progress.
wa6smn is offline
post #18 of 67 (permalink) Old 08-17-2009, 11:41 AM
How did you end up with the same user name as mine?
Mountain Man is offline
post #19 of 67 (permalink) Old 08-17-2009, 12:10 PM
My fender should be here today......
post #20 of 67 (permalink) Old 08-18-2009, 04:29 PM
Hey GTI
I just ordered the fender and am going to try a similar approach to attach it but instead use long hose clamps to wrap the triple clamp. I will cut 4 slots in the fender and thread the end of the two hose clamps through the fender and up and over the clamp back down through the other slot and screw it up tight underneath. I don't have access to any real tools or materials to fabricate brackets and don't know why this wouldn't work. Probably wrap the triple clamp with black electrician's tape first for added grip. I will try to punch out the slots in the fender with a screwdriver which should give the right shape. Will let all know how it works out and try to get come pics up too - if it works.
