Mirror Vibration - Kawasaki Versys Forum
post #1 of 8 (permalink) Old 07-11-2009, 07:00 PM Thread Starter
SeanS's Avatar
Mirror Vibration
Is there anything I can do about very bad mirror vibration? I can barely make out objects in them at speed. Or is that the way it's suppose to be? Help...
SeanS is offline
post #2 of 8 (permalink) Old 07-11-2009, 07:11 PM
cetzel's Avatar
If you want to fix it without replacing the handlebars for something aluminum (reduces vibration) there's caulk
http://www.kawasakiversys.com/forums...rror+vibration
And I read somebody laid the bike on its right side and dumped lead shot down into the stock handlebars.
I fixed mine the hard way: I slid the bike across the pavement for about 30 feet. It helped me decide to replace the stock handle bars with ProTaper bars. Although the vibration is still there I can at least tell the difference between a Cop and a Camry now.
Bar-end mirrors are a good cheap solution too. Mine are clear as crystal no matter what revs.
If you search for "Mirror Vibration" on the forum there is more info on the methods I described.
2009 Versys
2000 Vulcan Drifter 800
cetzel is offline
post #3 of 8 (permalink) Old 07-12-2009, 08:38 PM Thread Starter
SeanS's Avatar
Thanks for the info. I was looking in the wrong section.
I am not afraid of the dark. I am afraid of the NINJAS that hide in the dark.
06 Kawasaki KX 450F (The Beast)
09 Kawasaki Versys 650
SeanS is offline
post #4 of 8 (permalink) Old 07-13-2009, 04:21 PM
vibrating mirrors
i have put the kawa z750 mirrors on my kawa. I have also put the white tape wich you use for gasfitting around all threads. It seems to have a dampening effect on vibrating.
UFMRDR is offline
post #5 of 8 (permalink) Old 07-13-2009, 09:15 PM Thread Starter
SeanS's Avatar
Thanks mate.
SeanS is offline
post #6 of 8 (permalink) Old 07-13-2009, 09:51 PM
What bar end mirrors did you get that were cheap? The ones I saw were to pricey for me.
Docteric is offline
post #7 of 8 (permalink) Old 07-14-2009, 06:59 PM
tomla's Avatar
the kawasaki z1000 mirrors vibrate less than the stockers, are wider, and look way better. I tried adding caulk inside my left mirror...helped a little...if you try this, use stick on wheel weights that you can adjust till you get the right weight, then you can transfer the correct weight of caulk inside the mirror.
tomla is offline
post #8 of 8 (permalink) Old 07-14-2009, 10:47 PM
potus2012's Avatar
My mirrors get a lot clearer when the RPM's get to 5k. Grab a gear or ride faster!
potus2012 is offline
