Colour Matched Radiator Cowl - Kawasaki Versys Forum
post #1 of 18 (permalink) Old 06-23-2009, 07:41 PM Thread Starter
sambamboo's Avatar
Just Curious.. as I'm getting a little painting repair done to my right side fairing soon and I'm interested in getting a portion of the radiator cowl painted the same metallic lime color as well.
Has anyone painted any of their radiator cowl and if so could they post some pictures just to see if it works or if it spoils the lines of the 'V'
cheers
sambamboo is offline
post #2 of 18 (permalink) Old 06-23-2009, 08:37 PM
Hi Sambamboo,
It would be . A cheap and easy way to test and find out is to cut out a similiar color sticker and place it on the radiator cowl.
You will know what you like ..
post #3 of 18 (permalink) Old 06-23-2009, 09:00 PM Thread Starter
sambamboo's Avatar
I'll probably just do a quick Photoshop on it tonight actually ..i was just curious if anyone had done it.
post #4 of 18 (permalink) Old 06-23-2009, 09:12 PM
Unless you really work at it the texture won't match.
I think that might make a noticeable (negative) difference.
Maybe with enough priming and sanding that could be eliminated, in which case it would probably look pretty good.
Shatrat is offline
post #5 of 18 (permalink) Old 06-23-2009, 10:44 PM Thread Starter
sambamboo's Avatar
took a stab at it
what do you think
post #6 of 18 (permalink) Old 06-23-2009, 10:52 PM
I think I like it.
So you are going to leave portions matte black?
I think having a little color there adds some balance that does seem missing.
Then the major problem becomes what happens if it gets scuffed again after putting so much thought/effort into it?
Shatrat is offline
post #7 of 18 (permalink) Old 06-23-2009, 11:07 PM Thread Starter
sambamboo's Avatar
and now for the extended color option
any feedback appreciated btw i do have the hepco & becker guards installed so they will protect them.
post #8 of 18 (permalink) Old 06-24-2009, 07:46 PM
MHansen105's Avatar
sambamboo,
Your second option looks better. Connecting the green areas makes the bike look more "solid" and grounded. Nice job! Post pics of the real deal when you're done!
Monte
_____________________________________________
"I've always been crazy, but it's kept me from going insane." Waylon Jennings
MHansen105 is offline
post #9 of 18 (permalink) Old 06-24-2009, 08:35 PM
BayouVersys's Avatar
I did some paint work on my 08'. Used Krylon Fusion...worked killer. The only prep I did was wipe down the cowls with alcohol and painted. I also painted the frame covers on the sides. It's been almost a year and still looks great. Go for it dood.
BayouVersys is offline
post #10 of 18 (permalink) Old 06-24-2009, 09:10 PM Thread Starter
sambamboo's Avatar
Ya i think the second one keeps the flow of color better from the rear of the bike down to the green on the front fender. i think its a go
post #11 of 18 (permalink) Old 06-24-2009, 09:31 PM
Hi Sambamboo,
the 2nd one looks better.
What the name of the computer program you are using to do this colouring testing?
post #12 of 18 (permalink) Old 06-24-2009, 09:41 PM
I believe he said he was going to "Photoshop" it.
post #13 of 18 (permalink) Old 06-24-2009, 09:52 PM
siyeh's Avatar
siyeh is offline
post #14 of 18 (permalink) Old 06-24-2009, 09:59 PM Thread Starter
sambamboo's Avatar
The application is called 'Paintbox' ..its a small freebee program on the net
I was going to use Photoshop ..but for what i needed to do this program is way simpler and easier.
post #15 of 18 (permalink) Old 06-25-2009, 01:32 AM
Thank you. Nice program to play around with.
post #16 of 18 (permalink) Old 06-25-2009, 01:56 AM
This is my version of the painted side panels, ermax belly pan and hugger...
maxx is offline
post #17 of 18 (permalink) Old 06-25-2009, 07:53 AM Thread Starter
sambamboo's Avatar
I love the Corbin seat Siyeh..
After looking at the painting of your rad cover and center plastics i think i will alter my paint idea to yours a little.
I think I'll only doing the rad cowl and even then leave a couple of spots unpainted (basically around the lower bolt hole, and around the top near the indicator mounts.)
and Maxx ya that Ermax stuff is awesome ...i have to wait for the Aussie dollar to get a bit better before i can afford em tho.
post #18 of 18 (permalink) Old 06-25-2009, 08:46 AM
+1 on that blue, very sharp Maxx. Sambamboo when your done post up the pics of your ride. I have got to get that Ermax chin spoiler.
