Engine Guard? - Kawasaki Versys Forum
post #1 of 15 (permalink) Old 06-05-2009, 06:39 PM Thread Starter
Engine Guard?
Greetings,
I am a new Versys owner (green) and have been looking for an engine guard. I found this one http://www.happy-trail.com/Kawasaki%...e%20Guard.aspx and am wondering if anyone here has tried it. You can also get foot peds for it too.
Also, are engine guards better than the sliders I've seen posted here on other threads?
Thanks!
Olah is offline
post #2 of 15 (permalink) Old 06-05-2009, 07:25 PM
IMO guards are better then sliders. I have the Hepco-Becker guards and like the fit and the way they follow the lines of the bike. I had the Happy-trails guards shipped to me by mistake, but they looked good too. The SW-Motech guards did nothing for me.
tommylikesbeer is offline
post #3 of 15 (permalink) Old 06-05-2009, 07:59 PM
MN_Smurf's Avatar
The Happy Trails guards and HB guards protect the radiator....the SW Motech guards protect the lower engine cases. Any of them are better than sliders.
My preference is SW Motech (from twistedthrottle.com).....
MN_Smurf is offline
post #4 of 15 (permalink) Old 06-05-2009, 08:05 PM
Photo0006.jpgHepco & Becker looks great on the bike. Or at least I thinks so and solid.
JERRYES is offline
post #5 of 15 (permalink) Old 06-05-2009, 08:10 PM
Guest
Hepco and Becker for sure!
my2sheps is offline
post #6 of 15 (permalink) Old 06-05-2009, 08:33 PM
Olah.
HB. Guards give better protection but have seen HB with sliders attached.
post #7 of 15 (permalink) Old 06-05-2009, 11:26 PM Thread Starter
Wow, Thanks for all of the informative and timely feedback!
Olah is offline
post #8 of 15 (permalink) Old 06-06-2009, 12:02 AM
VeeWNC's Avatar
I've got the Happy Trails
They work OK, but I do have a gripe or two about them. For one, the bar on the engine guard passes directly beneath the oil drain plug. In order to drain the oil, I have to loosen the guard fittings on one side of the bike to pull the guard out of the way.
The bash plate does a good job of keeping dirt and rocks off of the lower engine and oil filter, but it isn't heavy enough to withstand a really strong impact, say from a protruding rock. Also, my fender extender sometimes snags the top of the guard plate -when that happens, it holds the forks in place and keeps them from turning easily. That can really be disconcerting when you're not expecting it. All that you have to do to dislodge it is to give the handlebars a good twist, but if you're underway, that might not be a good thing to do.
I'm going to add a curved plate to the top of the bash plate to keep the fender extender from snagging.
VeeWNC is offline
post #9 of 15 (permalink) Old 06-28-2009, 12:19 PM Thread Starter
Update:
I went with the SW Motech engine guards and had my mechanic install them. I got the footpegs as well and they are great for all of the highway riding I do.
Two issues:
1. Now that the guards are installed, I notice that the handlebar vibrations are much more pronounced, especially at 60+ mph. Has anyone else noticed this?
2. There is very little clearance for my right foot to fit between the bottom of the crash bar and the brake. It works but I find myself having to feel for the brake peg.
Any thoughts or solutions?
Thanks!
Olah is offline
post #10 of 15 (permalink) Old 06-28-2009, 04:07 PM
Xo0oM's Avatar
Originally Posted by Olah View Post
Two issues:
Actually, I think I noticed this too after I put the SW's on. Still love them tho..
Xo0oM is offline
post #11 of 15 (permalink) Old 03-21-2012, 03:05 PM
tommyt37's Avatar
i had the opportunity to field test the sw motech guards-you made the right choice.
i noticed a very high frequency vibration in the bars quite a few miles after install. when i checked things over, i found a loose engine mount bolt on the left side that is used in common with the guards. had loctite blue and still loosened up. tightened everything up all the way around and no more vibes. 2 thousand miles later the vibes are back. this time it was the right side. tighten up-no vibes. something to check. maybe use loctite red.
Saw this video on line probably made the rounds all ready...
http://youtu.be/7bEDVpLvP_4
tommyt37 is offline
post #12 of 15 (permalink) Old 03-28-2012, 08:55 PM
kurt's Avatar
I tried everything with my SW Motech but I can't do anything with the vibrations... now I installed my new Hepco&Becker engine guard and it's perfect... No vibrations and looks great, easy to install too.
it is what it is...
kurt is offline
post #13 of 15 (permalink) Old 03-28-2012, 09:47 PM
goat12's Avatar
I have the SW Motech's on my 2011. Despite worrying about vibes after reading posts on the forum I gave them a shot. Not only was there no addition of vibration; I was also able to make them work with my evap cannister without more than a little plastic editing with my dremel. She definitely rides differently with the added weight down low, but I've gotten used to it. A bit more bottom heavy I guess.
goat12 is offline
post #14 of 15 (permalink) Old 03-28-2012, 10:50 PM
AzItLies's Avatar
This is what the Givi ones look like. I'm pretty happy with them, no vibrations to speak of (my luck that will change tomorrow!)
AzItLies is offline
post #15 of 15 (permalink) Old 07-01-2012, 04:01 AM
VOz
VOz's Avatar
I notice you have a lanyard attached to your bike. Is this for an airbag jacket? I have a Hitair Motorad airbag jacket, looks like the same lanyard.
Voz
Sydney, Australia
2012 Kawasaki Versys 650
VOz is offline
