Do you think these spools will fit? - Kawasaki Versys Forum
post #1 of 5 (permalink) Old 05-27-2009, 08:21 PM Thread Starter
Guest
I want to get some swingarm spools and I read that 10mm ones should work. I like the look of these:
http://cgi.ebay.com/ebaymotors/ws/eB...ayphotohosting
I like the idea of them being extended to protect in a crash, and the price is right. I had a set of similar delrin spools on my SV and they helped a lot in a low-speed drop I had.
Think they'll fit? Should I drop $10 and test em out for the greater good?
Thanks all!
schleppy is offline
post #2 of 5 (permalink) Old 05-27-2009, 09:52 PM
brothercannon's Avatar
Yup those should work.
brothercannon is offline
post #3 of 5 (permalink) Old 05-27-2009, 11:38 PM
They look just like what I've got.
blz2dwl is offline
post #4 of 5 (permalink) Old 05-28-2009, 10:10 AM Thread Starter
Guest
My only real concern is the fact that one side of the spool threads on the Versys' swingarm isn't totally flush with the swingarm itself.
I may just bite the bullet and get em.
schleppy is offline
post #5 of 5 (permalink) Old 05-28-2009, 10:17 AM
Um, I believe they should be flush... Well you could just use washers to make up the difference. If the washer(s) are too large just grind down a flat spot on the outside of the washer to so it lays flat.
