Dirt Bike style front fender - Kawasaki Versys Forum
post #1 of 14 (permalink) Old 04-28-2009, 05:35 PM Thread Starter
gti20vturbo's Avatar
Does anyone know of a bracket that we can mount on the Versys to allow a dirt bike front fender (see below)? I thought the bottom tripe was drilled and tapped on the bottom but its not. A thin fork brace type mount would work (Speedy you reading this?) that was drilled and tapped.
ST1300, Versys, SV650S
gti20vturbo is offline
post #2 of 14 (permalink) Old 04-28-2009, 07:28 PM
Keep in mind you have to find a way to protect the fork legs if you remove the stock fender. It looks good though.
jhedges is offline
post #3 of 14 (permalink) Old 04-28-2009, 07:36 PM Thread Starter
Yeap thats the easy part.
post #4 of 14 (permalink) Old 04-28-2009, 10:00 PM
Hurricane's Avatar
i guess that's a husqvarna sm 610 front end
http://www.youtube.com/watch?v=6SjW1AJp5nw
Hurricane is offline
post #5 of 14 (permalink) Old 04-29-2009, 06:15 PM
Zammy's Avatar
Take a look at the front fender on the '09 Motard 250 Kawasaki .It's black so it goes with any color and it's for a 17'' wheel so the proportion is right . I'm thinkin' about putting that on my Green V.
Zammy is offline
post #6 of 14 (permalink) Old 04-29-2009, 06:18 PM
Zammy's Avatar
Zammy is offline
post #7 of 14 (permalink) Old 04-29-2009, 07:08 PM Thread Starter
Thats a decent looking one for sure. I have found several I would like to check out but the issue we have is the bottom of our tripleclamps are not drilled and tapped for the bolts that hold the fenders on like on a dirt bike.
post #8 of 14 (permalink) Old 04-29-2009, 09:27 PM
Zammy's Avatar
You'll hafta come up with a wrap around or clamp on bracket.
Zammy is offline
post #9 of 14 (permalink) Old 04-29-2009, 10:20 PM
Post
Was curious if the brake lines will be an issue? There is a crossover feed from one side to the other...
contractor is offline
post #10 of 14 (permalink) Old 04-30-2009, 08:38 AM
Zammy's Avatar
I'd be inclined to chop the front half of a used front fender and paint it flat black.
Zammy is offline
post #11 of 14 (permalink) Old 05-04-2009, 01:16 PM
ag_streak's Avatar
Looks like yes. I had the same issue with my V-strom and replaced the front lines with a braided-steel kit that uses two separate lines from the master cylinder, one to each side, eliminating the cross-over tube.
2011 Versys
ag_streak is offline
post #12 of 14 (permalink) Old 05-11-2009, 08:41 PM
high fender fitment
clearly the challenge here is in dealing with the routing of the dual brake cables. Speedy - can you come up with one of your slick solutions?
blueversys is offline
post #13 of 14 (permalink) Old 05-14-2009, 05:55 PM
Ummm... get a twin set of stainless steel lines from the master cyl? I mean if you're already modding the front...
CC
CrazyCarl is offline
post #14 of 14 (permalink) Old 05-16-2009, 08:25 AM
Originally Posted by gti20vturbo View Post
... but the issue we have is the bottom of our tripleclamps are not drilled and tapped for the bolts that hold the fenders on like on a dirt bike.
Drill 'em and tap 'em. They are only cast aluminum, so a few minutes with a hand drill and a tap would make quick work. Or scrap the tap all together and drill clearance holes for a nice stainless steel button head hex bolt. Use a couple of nylon locking nuts to hold everything tight and fender washers to distribute the load.
Corey
corey872 is offline
