Barkbusters - Kawasaki Versys Forum
post #1 of 21 (permalink) Old 03-17-2009, 11:03 PM Thread Starter
Barkbusters
Just installed the Barkbuster kit from Twisted Throttle
Here's the photoblog of the install
Yes I know they arn't quite level. We just got the bike 2nd hand, It's been dropped on the left and the bars are tweaked slightly.
Chris
BugR is offline
post #2 of 21 (permalink) Old 03-18-2009, 01:34 PM
Thanks BugR
I was hopeing to to the same thing on my V.
It looks like it's not too hard to do.
looks good
Cheers
cdaversys is offline
post #3 of 21 (permalink) Old 03-18-2009, 02:47 PM
Briar Rabbit's Avatar
Nice Pics!
Do the Barkbusters hit the windscreen?
Briar Rabbit is offline
post #4 of 21 (permalink) Old 03-18-2009, 04:31 PM
They look good! Nice job...
post #5 of 21 (permalink) Old 03-18-2009, 09:50 PM Thread Starter
The barbusters clear the screen (It's a Madstaff not std)
BugR is offline
post #6 of 21 (permalink) Old 03-18-2009, 11:53 PM
nvoelsch's Avatar
Hey, that looks like mine! Different windshield though.
nvoelsch is offline
post #7 of 21 (permalink) Old 03-21-2009, 07:39 AM
I've got the barkbusters on my bike. Got them from twistedthrottle.com. They're over built for just street use but they are very solid and I'm very happy with them. If you get them mount the handlebar clamp just above the black plastic cable hanger attached to the handlebar. I found that the best place to mount it after trying it both above and below the cable hanger.
walt is offline
post #8 of 21 (permalink) Old 03-21-2009, 09:24 AM
Guest
Originally Posted by Briar Rabbit View Post
Nice Pics!
No on the stock screen.
Yes if you have the Givi screen.
Enrage is offline
post #9 of 21 (permalink) Old 03-22-2009, 08:59 AM
They miss the stock screen by at least 3 inches. They also went on very easily.
walt is offline
post #10 of 21 (permalink) Old 03-23-2009, 11:56 PM
Those Barkbuster's look great and seem easy enough to fit.
Could you supply the part numbers for all the pieces required, my local store has a catalogue but it's hard to make out what's required.
Thanks!
angusog is offline
post #11 of 21 (permalink) Old 03-24-2009, 05:23 AM
I ordered the Barkbusters from twistedthrottle.com. My dealer didn't have a source for them. Check the web site to make sure I have the numbers right before you order. I threw my paper work away so I got these from the web site. I hope I have them right. Hand gaurd BB.BHG6. Mounting kit BB.BSC.STD. Bar end weight kit for Versys BB.B56. I ordered the black skid plates which cover the curve on the aluminum frame BB.BHG2.
walt is offline
post #12 of 21 (permalink) Old 03-24-2009, 09:09 AM
Thanks Walt, I will go and order some. I found the model specific parts on the site you mentioned. Linky here
angusog is offline
post #13 of 21 (permalink) Old 03-24-2009, 02:18 PM
spiderman's Avatar
I just ordered the same kit yesterday but without the bar end weights. I think I remember someone mounting these without the weights but I can't seem to find the thread right now. Anyone remember that info?
Jeff in Illinois
07 Bandit
03 KLR
82 Rokon
spiderman is offline
post #14 of 21 (permalink) Old 03-25-2009, 02:03 PM
spiderman's Avatar
Ah, nevermind - I found it. It was on the UK site. If anyone's interested its at:
http://www.versys.co.uk/index.php?op...5&topic=4864.0
They took the stock weights and machined them down to the proper spacer length.
Jeff in Illinois
07 Bandit
03 KLR
82 Rokon
post #15 of 21 (permalink) Old 03-25-2009, 10:19 PM
AvaChava's Avatar
Sorry if this has been covered but is there
any way to retain the STOCK bar end weights?
AvaChava is offline
post #16 of 21 (permalink) Old 03-27-2009, 09:31 PM
spiderman's Avatar
/retain the old bar weights?
I just made the Barkbuster installation this afternoon. I didn't order the recommended spacers but instead, just cut down the original bar weights to about 1" in length. The answer to your question though is Yes. I could have used the bar weights in their original form but it would have required bending the handguard frames slightly to accomodate the extra length. Then you would also need to get a pair of longer bolts to secure them, but I doubt that would be much trouble to locate.
Jeff in Illinois
07 Bandit
03 KLR
82 Rokon
post #17 of 21 (permalink) Old 03-28-2009, 05:05 PM
spiderman's Avatar
Avachava - I went back through some old posts and found where Dallasdon has done it but he used another brand of handguards. I don't see why it wouldn't work for the Barkbuster as well. Check out this thread
http://www.kawasakiversys.com/forums...hread.php?t=59
He posted some pictures of his installation.
Jeff in Illinois
07 Bandit
03 KLR
82 Rokon
post #18 of 21 (permalink) Old 03-28-2009, 06:02 PM
AvaChava's Avatar
I saw that, said the blind carpenter
OK, I saw that before but connecting
the dots in my mind is like pouring your
coffee in a sieve. You kinda get the
flavor but not the buzz. Thanks, Jeff;
that light at the end of the tunnel
might NOT be my reflection...
AvaChava is offline
post #19 of 21 (permalink) Old 09-09-2009, 09:05 AM
brokenhat's Avatar
Send a message via MSN to brokenhat
Off topic but what stand are you using please?
brokenhat is offline
post #20 of 21 (permalink) Old 09-09-2009, 09:06 AM
brokenhat's Avatar
I have a Vario screen, will they work with that without hitting? Thanks!
