Vista Cruise AND Hand Guards? - Kawasaki Versys Forum
post #1 of 23 (permalink) Old 01-22-2009, 10:28 AM Thread Starter
I've searched the forum but did not find a discussion regarding whether hand guards can be installed with a Vista Cruise throttle lock. I'm wondering if there are any clearance issues with hand guard mounts and the operation of the throttle lock.
Thanks for any insights.
[SIZE="1"]Ride. Good.
2019 F750GS
2014 R1200RT
2008 Versys (SOLD 11/19)
2003 ST1300ABS (SOLD 5/15)
post #2 of 23 (permalink) Old 01-22-2009, 11:06 AM
i run a universal cruise lock with a set of emgo hand guards...no issues
tsunamichop007 is offline
post #3 of 23 (permalink) Old 03-25-2009, 10:08 PM
RPrice's Avatar
I run a Vista Cruise Universal and KTM Handguards. No issues. I could send you a pic early next week if you want, but others have posted pics of installations basically identical to mine, and they have no problems.
regards, Bob
RPrice is offline
post #4 of 23 (permalink) Old 03-25-2009, 11:48 PM
No problem
Gustavo
Gustavo is offline
post #5 of 23 (permalink) Old 03-26-2009, 07:57 AM Thread Starter
Thanks...it works!
2019 F750GS
2014 R1200RT
post #6 of 23 (permalink) Old 03-26-2009, 10:37 AM
Gustavo, what brand are those handguards???
mudduck is offline
post #7 of 23 (permalink) Old 03-26-2009, 12:19 PM
RPrice's Avatar
I'm not Gustavo, but those are KTM handguards.
regards, Bob
RPrice is offline
post #8 of 23 (permalink) Old 03-28-2009, 05:24 AM
Dorian's Avatar
Gustavo; How did you install your Vista Cruise. The model I have (not yet installed) has a bar that attaches to the handle bar. With the type of hand guards I have a mount that sits inbetween the grip and the controls, right where the vista cruise mount goes. I see that you aren't using that mount. How does it work that way.
Dorian is offline
post #9 of 23 (permalink) Old 04-29-2009, 12:24 AM
Dorian - I'm guessing the model you got is the "universal" type. Machog has one of those. Mine is the Honda/Kawasaki dual throttle cable type, it has a small tab on the back side that is supposed to hookup to one of those throttle cables. Of course, the Versys does not have any exposed cables, so I attached it to the back of the throttle cable/kill switch housing with a small screw.
To eliminate the risk of damage to the throttle cable, I cut the tip off, so that it does not protrude much into the housing. You will want to test that and verify it doesn't on your installation.
I have an NEP on the V-Strom, I think the Vista Cruise is a little nicer because it's easier to engage/disengage (both cost the same).
Two things to keep in mind. The Versys throttle grip is installed very close to the switch housing, I ended up cutting the end to eliminate the excessive friction and the throttle tube has a ridge right where the throttle lock should go, so that also interferes with smooth throttle action. I filed the ridge off. It's more work than I have ever had to do on any other bike, but having the throttle lock is really worth it on long trips.
Gustavo
Gustavo is offline
post #10 of 23 (permalink) Old 05-14-2009, 05:57 PM
carter's Avatar
a question about your KTM handguards...what type or model are they? I've checked w/ dealer before and they had a hard time cross refrence to V. Also I've been considering the Kaoka cruise. It looks like the Vista is 1/3 the cost. does it work well for you?
carter is offline
post #11 of 23 (permalink) Old 05-14-2009, 06:11 PM
Machog's Avatar
Dorian, if this is the model you are referring to, I put a spacer in the top bolt of the housing along with a longer bolt obviously. Works great.
Machog
Machog is offline
post #12 of 23 (permalink) Old 05-14-2009, 07:16 PM Thread Starter
These: http://www.ktmtwins.com/950superendu...207910030.html
I put them on, they work well and look good. Takes a bit of trial and error to get them lined up so everything clears, but less than an hour start to finish.
2019 F750GS
2014 R1200RT
post #13 of 23 (permalink) Old 05-14-2009, 11:07 PM
RPrice's Avatar
The post from Bone's details the KTM handguards I have. They work great, and no issues! The Vista cruise Universal works great, just incorporate the install into the Brake clamp, and you will have to use spacers to accomodate. All this has been detailed in prior posts. You will be happy!
regards, Bob
RPrice is offline
post #14 of 23 (permalink) Old 05-15-2009, 05:45 AM
Dorian's Avatar
Machog
I have seen your approach in a previous post and thought it was great but, the problem I had is that the Acerbis hand guards I have, have a mounting bracket in between the grip and the control housing. What I ended up doing is cutting a peice of metal to bolt into that bracket and then bolting the arm of the Vista Cruise to that. When i get the chance I'll take some pictures. Thanks for your reply and suggestion.
Dorian is offline
post #15 of 23 (permalink) Old 05-15-2009, 10:04 AM
carter's Avatar
Thanks alot, that really helps.
carter is offline
post #16 of 23 (permalink) Old 05-16-2009, 12:56 PM
I have "Zetas" with my Universal, mounted like "Machog" did.
post #17 of 23 (permalink) Old 06-06-2009, 06:56 PM
I just got and installed my vista universal cruise and it's installed the same way as Machog's is and I can't for the life of me get the dang thing to hold the throttle for more than 1-2 seconds before I have to grab the thing and reset it again. The way it's set now I can release for almost 2 seconds to stretch my fingers before I'm going 10 mph slower and if it's not on my throttle doesn't snap back when I let go, I have to roll off. It's not safe at this point in my opinion, but could really use some pointers on what I can do with it to make it work, or should I just save some cash and buy a kaoko?
What I was hoping when I bought this thing was to have the ability to take my hand off the throttle for a minute tops to rest my fingers/wrist and as it is now with what I do have I spend more time trying to make it work than paying attention so I figure it's got one more day or two before I chunk it in the trash.
thanks for any help!
Postholes
Postholes is offline
post #18 of 23 (permalink) Old 06-06-2009, 07:42 PM
Machog's Avatar
Hmmm that's odd.
I can take my hand off on the flat or flatish for quite a while to rest my hand.
Its possible to crank the domed nut (just above the spring in the photo) down, so you can hardly move the throttle.
What happens when you do that? If that locks down and the Vista ring is tight on the hand grip-it souldn't be able to move.
Machog
Machog is offline
post #19 of 23 (permalink) Old 06-07-2009, 09:15 AM
RPrice's Avatar
Postholes,
Ditto on what Machog said, that's all I can think of. I had to adjust mine tighter, with dome nut, after experiencing a similar problem, but now it's fine.
regards, Bob
RPrice is offline
post #20 of 23 (permalink) Old 06-07-2009, 01:23 PM
PLUS - you can 'shim' the domed nut with washers under it for more tension, and if you feel that the 3 little socket set-screws are deforming the rubber piece rather than holding, try a piece of .020" brass shim stock under each set screw. That's what my KLR requires.
Cheers,
