Stock Hand Guards Modifications - Kawasaki Versys Forum
Like Tree2Likes
  • 1 Post By turbof4nny
  • 1 Post By Buffalo_Bob
post #1 of 12 (permalink) Old 11-02-2019, 06:16 PM Thread Starter
turbof4nny's Avatar
Hello all, Has anyone else noticed and done anything about the underside of the hand guards not blocking any air? I feel petty for complaining about it, but it's quite annoying in colder weather. The top of my hands will be nice and shielded, but my thumbs and fingertips around the bottom of the grips are totally exposed to the air because the stock guards don't cover below the grip line. I never realized this until it got chilly outside and after my daily commutes my fingers are frozen! This is on a 2018 V650LT
funflyingguy likes this.
turbof4nny is offline
post #2 of 12 (permalink) Old 11-02-2019, 06:34 PM
Yes , but for some reason my right hand gets colder than my left hand. I’m trying to figure out some way to use one of my bigger Handguards of I might get some Oxfords super handlebar muffs . Only $49.00 on Revzilla or Amazon.I really don’t like having to wear Thick winter gloves.
Modene is offline
post #3 of 12 (permalink) Old 11-03-2019, 05:11 AM
They are a bit high, yes.
You can loosen all the tie points and move them down about the width of the bone. But they will likely touch the console when steering fully.
FYI, the most important and I'd say mandatory mod you should do is to tie the inside end of the bone to the triple clamp.
During a crash this handguard will flip up because the mounting has no strength. Do not even try to tight the bolts harder you will either strip the allen head or the threads and they will still move. Buy real ordinary galvanized or stainless bolts and washers to replace them all (2 on each clamp plus the small one connecting the bone). This allen key head **** will strip just looking at it.
I loop 3 times a black paracord in the hole at the end of the bone then under the triple clamp.
If you don't tie the handguard this way, you can be sure of 1 of 2 outcomes:
1-fall on left side will lift the clutch cable and beak your adjuster nut
2-fall on right side will possibly crack master cylinder
Why 3 loops? because math: rope rating * 6.... Trying to ensure it can take plenty of weight.
I did file the sharp edges of the bone slot to round it and avoid it cutting the rope upon tension.
dddd is offline
post #4 of 12 (permalink) Old 11-03-2019, 08:47 AM
Sounds like a sound modification. Any pictures of the mod?
Buffalo_Bob is offline
post #5 of 12 (permalink) Old 11-03-2019, 09:23 AM
AmbientMoto's Avatar
I'd like to see a photo of this as well... I need to sort my handguards/cold weather situation.
Here to learn.
AmbientMoto is offline
post #6 of 12 (permalink) Old 11-03-2019, 11:15 AM
it was just an FYI...
Doesn't solve any cold fingers issues.
But why not...
dddd is offline
post #7 of 12 (permalink) Old 11-15-2019, 09:00 AM Thread Starter
turbof4nny's Avatar
Thanks for the tips! The handlebar tip allen heads are impossible to loosen!! I think I'm going to end up getting a new pair
post #8 of 12 (permalink) Old 11-15-2019, 10:56 AM
Has anyone tried the Oxford Super Muffs mentioned above? Do the fit over the handlebar guards? I tried a different pair (Audew) and they were not large enough.
2016 Versys 650, Carbon Gray/Black
Hankster is online now
post #9 of 12 (permalink) Old 11-15-2019, 02:48 PM
I did install my Oxford super muffs ,they (((will )))fit over the Handguards I used them for two days then took them off. I think they help but air still flows in . Maybe some black Gorilla Duct tape would help. Probably wouldn’t buy Again.
Modene is offline
post #10 of 12 (permalink) Old 11-15-2019, 03:36 PM
Thanks, Modene. Maybe heated grips are the only complete solution.
post #11 of 12 (permalink) Old 11-15-2019, 04:12 PM
And because of how good they are, and how WELL they work, I recommend the KOSO Apollo heated grips.
IMG_2849 by Ed Copeman, on Flickr
IMG_2850 by Ed Copeman, on Flickr
The 'controls' and the ON/OFF are on the left grip, w/ a light that changes color as you select different levels of heat.
post #12 of 12 (permalink) Old 11-15-2019, 04:15 PM
In post #8 of this thread
https://www.kawasakiversys.com/forum...andguards.html
I added lots of pics of a handguard mod I did to my Gen 3.
